Scratch Build – In Progress Cherry wood case water cooled
Discussion in 'Project Logs' started by Tale Gunner, 26 Feb 2007.
  1. Tale Gunner
    Tale Gunner What's a Dremel?
    15 Dec 2006
    Yes that was a great shot of the case. Its all coming together. Thanks mvagusta.
  2. NysoO
    NysoO Handcrafted
    2 Nov 2006
    It has indeed a nice look! Keep it coming man, good job :)
  3. Tale Gunner
    15 Dec 2006
    Thank you. I'm heading up to Woodcraft in a about an hour to make a purchase for some additional things.
  4. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    you better!!!
  5. Tale Gunner
    15 Dec 2006
    Its time again to make some blanks for the trim. This time its easier, being that all I need is 3/4 square blanks to be routed with the cove bit. just take a board any board much like this one.
    Cut some lengths to which you need for the trim.
    Plane them to size (in this case 3/4")
    Square them up with a jointer or saw depending on if you can get a good true cut.
    And then cut them to the desired width (again 3/4")
    Note that some of these appear to be less then straight. That is correct. Wood, after cutting, can deflect. That's because the grain at which you just cut may have had tension on keeping itself together, Cutting them allow the board to "bend". That's why I cut so many. I want to insure that the trim is true when its routed and them cut for final installation.
  6. x06jsp
    2 Apr 2007
    looking good:thumb:
  7. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    TG,
    A really great job!!! I like watching your progress and skill.:thumb:
  8. Tale Gunner
    15 Dec 2006
    Ahh but youre the one nominated for Project of the month. Great work to you. Thank you
  9. Tale Gunner
    15 Dec 2006
    I can always count on you after a post. LOL thank you
  10. Morphine-Kitty
    Morphine-Kitty Dead account.
    22 Apr 2007
    The specs sound awesome, and the computer is looking great. :thumb:
  11. x06jsp
    2 Apr 2007
    ya sure can tg:thumb:
  12. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    looking good man, the end is getting near!
  13. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    A thicknesser!
    Ouch. I wish.
    H.B.
  14. ComputerKing
    8 Sep 2006
    man your work is soo clean and you care about it! wow I love this wood skills.. good luck. I want see more
  15. Tale Gunner
    15 Dec 2006
    Thank you. This is really fun.
  16. Tale Gunner
    15 Dec 2006
    Humm I just finished taking apart the hardcano 10 and removed the parts to mod a custom plate in my system. Keep tuned
  17. Tale Gunner
    15 Dec 2006
    Not sure what a thicknesser is ? Anyone could do this with patience and practice.
  18. Tale Gunner
    15 Dec 2006
    Yes when you have a passion for something you really try to pay attention to details.
  19. Tale Gunner
    15 Dec 2006
    I have been looking into some more work for myself and this machine. Heres what I already have in place.
    Nice tight Lines on the front of this machine.
    So I thought maybe I could take out the Hardcano and do something like this.
    And put it in the top space.
    Whats everyone think? get back to me...
  20. ComputerKing
    8 Sep 2006
    coool yeah if you did that it will look nice.. DO it.. Good luck
