Chieftec Blacklight Mod +++UPDATE+++ 7/22+++ @ 60%
Discussion in 'Project Logs' started by B3HEMOTH, 16 Jul 2004.
  1. B3HEMOTH
    B3HEMOTH What's a Dremel?
    16 Jul 2004
    ahh come on guys, reply, im looking for some feedback, or other ideas
    :sigh:
  2. henson0115
    henson0115 Banned
    16 Apr 2004
    i was wondering were you got your uv sleeving kit from i want a blue one :D
  3. B3HEMOTH
    16 Jul 2004
    like it says superimposed over the picture, svc, lol
    but i think they are out of stock on the blue ones
  4. Firehed
    15 Feb 2004
    Those things never have enough heatshrink anyways. Most mod shops sell sleeving, just buy how much you need plus a ton extra :)
  5. H2O-G33K
    H2O-G33K What's a Dremel?
    25 Jan 2003
    Double-sided tape or something along those lines. 've been toying with the idea of using a router to cut back the sides of a sheet of perspex so it'd sit flush with the metal... that'd look neat :)
  6. B3HEMOTH
    16 Jul 2004
    ?? what do you mean
    btw, all my svc stuff came in yesterday, im taking the case to paint tommorow morning :D
  7. uNsaiN
    uNsaiN What's a Dremel?
    1 Jun 2004
    I personally think bolting it on looks better and more professional.
  8. B3HEMOTH
    16 Jul 2004
    i think I'm gonna go with bolting, for 1, it looks really clean from all sides, and 2, it is easily removed if i need to
    btw, do you guys know what is the best way to replace drilled out rivets?? I'm thinking a tiny nut and bolt, or is there some way to easily re rivet them?
  9. B3HEMOTH
    16 Jul 2004
    double post :(
