Chieftec dragon ::UPDATE Mar 25::
Discussion in 'Project Logs' started by x3r0, 12 Dec 2003.
  1. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    thanks for the tip
    but it dosent really apply since theres no paint on the panel yet :lol:
    anyways... i'm getting the hang of the dremel now... the only problem is that for me to "get the hang" of the dremel... i seem to have wasted almost 17 cutting disks and shattered another 5 or so.
    :grr:
    the disks are starting to last a bit longer now though.
    window looks good so far as well :hip:
    it's going to take some work though to cover upt he holes on the panel. :blah:
  2. x3r0
    29 Oct 2003
    after a couple of coats of white paint.
    no where near a mirror finish but it does have a shine to it.
    and nowhere near finished yet.
    it dosent really show it on the picture but on the right hand side of the door.... is a bit ****ed.
    i put a little to much paint on one of the coats and it started to bubble, the smart thing to do would have been to wait till it was dry and sand it out.... but being the dumb ass i am i took a cloth to it and left big streaks down the paint like scratches :grr:
  3. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Yes.
    This case is going to look good. :D
  4. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    thats looking very nice
  5. x3r0
    29 Oct 2003
    ok
    i think this is all i'm going to do today.
    esp since i ran out of ANOTHER 20 cutting disks :grr:
    i think i'm buying the wrong ones. :worried:
    anyways.
    here is the window.
    edit: there is something else i can do today
    i still have to bondo up those damn holes in the side panel.
  6. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looks nice love the window x3r0 :clap: :dremel:
  7. x3r0
    29 Oct 2003
    thanks :lol:
  8. bsodmike
    bsodmike Banned
    11 Oct 2002
    Damn, bondo is such amazing stuff!! Looking real good mate, this is gonna be so pimp ;)
  9. 3vil-Grin
    3vil-Grin What's a Dremel?
    25 Jun 2003
    great looking case so far!
    glad you went with white too...be different!!
    Man the dremel/bondo work you did looks awsome!!
    Hey about your cutting with the dremel...have you done a search or check out how or what type of disks everyone else uses for making window mods?! I know i have seen the actuall part number for certain disk that people use for such detailed cuts as yours is. It might help you in the long run, especial in the 'pocket book' area.
    Anyways cant wait to see more of this project!
  10. x3r0
    29 Oct 2003
    thanks for that, i'll have a search
    Atm i've been using the disks with the number "420"
    they arent re-enforced.... but they where fairly cheap and they came in packs of 20, so i'm not to fussed.
  11. STellY
    STellY What's a Dremel?
    24 Aug 2003
    wow this case is looking AWESOME....
    great bondo work and great lookin window!!
    i think i will subscribe :thumb:
    for dremel cutting discs.... usually by getting the most expensive ones you dont lose any money... as they last as long as 20 of the smaller ones...
    im not exactly sure what numbers are on the ones we get but we get the really thick and wide reinforced ones.... though u wanna wait til they are small to do detailed cuts.... so you do your straight lines first :)
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
    looking really good - that window, looks like a beetle head.
    :thumb:
  13. YingKo
    YingKo What's a Dremel?
    8 Sep 2003
    How much does it weigh with all the bondo on it?
  14. fonts
    fonts What's a Dremel?
    29 Oct 2003
    i carnt say how much it weighs but b4 he put the bondo in the front panel it was light as , now it weights alot more
  15. Tech-Daddy
    Tech-Daddy What's a Dremel?
    8 Oct 2003
    http://www.dremel.com/productdisplay/bit_template.asp?SKU=426&Color=CC0000
    http://www.dremel.com/productdisplay/bit_template.asp?SKU=456&Color=cc0000
    Reinforced wheels are the way to go.... trust me. Just let the wheel do the work, do not force it... but it looks like you dont need any advice from me on this! ;)
    Nice looking case!
    Keep it up!
  16. x3r0
    29 Oct 2003
    weee
    thanks for that
    exactly what i was looking for.
  17. Wicked Li'l Bender
    Wicked Li'l Bender What's a Dremel?
    9 Nov 2003
    Nice dremel work... I know what you are talking about on the Dremel disks breaking... You are using the cheap redish bonded emery style... they don't hold up for large cutting projects... You want to go with the ones that look like brown cutoff disk blades. they are reinforced with a fiberglass grid and have a much beter cutting action.... Like was stated earlier... save thelittle red ones for light work and touchup...
  18. x3r0
    29 Oct 2003
    thanks... your description matched the disks perfectly
    i'll look out for those reenforced ones next time i'm at bunnings :)
  19. McBug
    McBug What's a Dremel?
    18 Dec 2003
    Smooth White look
    I really like the white smooth front, something different that all those black cases....
    McBug :rock:
  20. x3r0
    29 Oct 2003
    ok, finally i started doing some more work
    the only reason i left it so long is because i dont have enough money / time to buy paint and plexi :(... but i got the paint today :D
    anybody want to report this thread to the guiness world records for longest time not being updated feel free.
    anyways... a pic of the case dismantled and being painted.
    and a close up of my dodgy paint job.
    after the painting ... all i have to do is touch up the window (dremel sanding discs), cover up the holes in the window (putty or araldyte for some strength)
    and then put her all back together :D
    edit: oh.... and buy some plexi and find some random / dodgy way to affix it to the window :grr:
    /me starts jumping for joy :waah:
