Case Mod - In Progress Chiller's Hybrid Level10
Discussion in 'Project Logs' started by Chiller1, 20 Sep 2010.
  1. Chiller1
    Chiller1 Hybrid Level 10 building
    20 Sep 2010
    allmost finished, just have to make it nice :
  2. Chiller1
    20 Sep 2010
    Two Koolance 360 rev1.1 , and Koolance SR-2 Classified full cover block are arrived :
    after received it, let's open up the full cover block SR-2 and change it a little bit :
    a lot of sanding it to get the nickel of it, and then the first layer of primer :
  3. Chiller1
    20 Sep 2010
    first layer mat black is on, tomorrow sanding it and paint it the last time for finishing touch,
    after when it's dry mount the block again and put it on the motherboard :
  4. Chiller1
    20 Sep 2010
    SR-2 full cover block is ready and mounted :
  5. Mongwopman
    Mongwopman King Ding-a-ling!
    28 Sep 2010
    WOW, thats a nice looking system!!!!
  6. Chiller1
    20 Sep 2010
    see also the rest of the pics before ?
  7. MrNitro
    MrNitro Performance Enthusiast =)
    26 Jun 2010
    This is just insane! I've never seen so much TEC cooling power together.
    Man, this is an awesome mod, good job.
  8. Chiller1
    20 Sep 2010
    pics of what i did today :
    from this :
    i made these, and a little bit more, only waiting for a new shipment of red connectors :
  9. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Wow! Inspirational stuff! Where do you source you kit from? I really struggled to find that Thermaltake GFX card PSU you used from my usual suppliers. (Thank you Amazon marketplace!)
  10. alex2k10
    alex2k10 New Member
    5 Oct 2010
    First off that mono is massive. Loving the work so far like the colour scheme as well good job.
  11. Chiller1
    20 Sep 2010
    k have two of them, the 650w version and in the closet i have also a 250w version of the GFX psu's.
  12. Chiller1
    20 Sep 2010
    today received package with connectors :
    i made this, and have to make more of them for the other cpu and vga power on mobo :
    and for the 90° corner of mobo has his place, tru the wall behind the Boreas Chiller, and also the tubing for the little isolated reservoir :
  13. alex2k10
    alex2k10 New Member
    5 Oct 2010
    looking good keep it up loving the detail in all of this.
  14. Chiller1
    20 Sep 2010
    The other cpu his power cable is also done, and the PciE cable also :
    Total overview of the powercables on the motherboard, the green circle is where the cables leave the case to the other side for connection to the powersupply :
  15. Vasskjøling
    Vasskjøling There is only one way to cool! WC!
    23 Jul 2010
    Ohh gaad! thats so sexy! I WANT IT!
  16. Chiller1
    20 Sep 2010
  17. rjkoneill
    rjkoneill New Member
    11 Feb 2008
    good log so far.
    nice to see a large mod to a case like this.
    the level 10 dosent have a lot of potential but it shows what a lot of imagination can do
  18. MrWizard
    MrWizard New Member
    5 Feb 2008
    Those 90 degree connectors are genius! It looks amazingly clean.
  19. Chiller1
    20 Sep 2010
    new parts in :
    Evga SR-2 1200w (peakload 1700w) psu
    PciE connector for GPU's with a 2200UF (MicroFarad) condensator and ferrit-cores :
    Cpu ATX power connectors, also with 2200UF (microFarad) Condensator and ferrit-cores :
    and te best part of the power supply is on the back of it lol :
    Also LGA1156 socket isolation and new inox Backplates for my SR-2 :
    also i got two red displays in for on my controller.
    To swat the green light lcd out for a red symbol / black background display :
  20. MrNitro
    26 Jun 2010
    Man, the PSU is awesome, but the cables...weird and ugly as hell =S
    You will hide them behind the mobo tray, right?
