Case Mod - In Progress Chiller's Hybrid Level10
Discussion in 'Project Logs' started by Chiller1, 20 Sep 2010.
  1. Chiller1
    Chiller1 Hybrid Level 10 building
    20 Sep 2010
    take a HB624 controller with ALMEGA88V chip :
    put some cables and a pot meter on it :
    with the pot meter 10K i can adkust the screen light :
    To see real time the 12v rail of the SR-2 powersupply, and monitore the power drawn of the three coolit coolers :
    cpu disable jumpers soldered for make the connector for it in front of the case :
    need to cut new Socket isolation because SR-2 has no big condensators next to the sockets, so i can use some more isolation : :
    putted also three temp sensors under the full cover blok, to measure the CPU PWM 1 en 2 and the NB temp
    with a Koolanc TMS-200 controller :
    total overview of the mobo in current state:
  2. Chiller1
    20 Sep 2010
    today little testing en measurement, the boreas chiller and the freezone will be hanged on the power use controller.
    but a lot of cables here that needs to be in the case fitted.
  3. Chiller1
    20 Sep 2010
    Alu plaat of 1.5mm is in, tomorrow making the adjustment of the mobo cover :
  4. Chiller1
    20 Sep 2010
    Today being busy with making place for all the usb cables, power led, hdd led etc to go away from mobo as fast as possible, not to show to much cables in case.
    Also adjusting some things to get the mobo cover enlargement fitted on case,
    used a lot of dremel cutting disks :
    And because the Evga SR-2 mobo doesn't have condensators like a normal LGA1366 mobo around the socket, i needed to make some new socket isolation kits for around cpu with more amramflex, pictures will say enough :
    And here you see the normal cut-out of a lga1366 socket kit and that for a Evga SR-2 mobo :
  5. Chiller1
    20 Sep 2010
    just bended the alu plate in the same curve as the standard mobo cover also have :
    The curve in the red circle, the green lines is untill where the mobo cover needs to get bigger for the bigger mobo :
  6. =WBG=cpt_custard
    =WBG=cpt_custard ferret
    29 Jul 2009
  7. Chiller1
    20 Sep 2010
    The original mobo cover has a serious cut-out for the adjustment,
    and you see the four square holes for mounting the new alu plate :
    This is the bottom of the original mobo cover, is a serious cut-out on,
    so Quad sli GTX480 still fitts :
    The new alu plate working on :
    And here it's fitted on the case base plate :
    Nice fit :
    And with the base plate of the big Boreas Chiller,
    you see that the ATX 24pin needs a cut-out, and two tubing with a BP fitting,
    also the Coolit Freezone V1 needs his place in this plate :
    And here you see what also needs to be cutt-out in alu plate :
  8. Chiller1
    20 Sep 2010
    Update after some hours work :
    the BP fittings are in place also the cutt-out for the ATX 24pin :
    BP fittings close-up :
    The outcome of the atx24pin :
    Inside of the ATX24pin :
    A Total overview with the motherboard and his power connectors installed for viewing cable routing :
    CPU1 Close-up :
    CPU0 Close-up :
    ATX 24pin close-up :
    ATX 24pin Close-up while motherboard is plugged in :
    Total View ATX24 pin :
    TOTAL overview mobo + atx connectors , alu plate :
  9. Chiller1
    20 Sep 2010
    busy on fitting the Coolit Freezone V1 under the mobo cover :
    And making by hand the honey roster like the original was a never ending thing, and was not nice,
    so i will make another solution as roster to protect the fan :
  10. Chiller1
    20 Sep 2010
    Working on the case again al day, bend the alu plate, making some acryl ready,
    the extra piece of hight is for the cpu power cables of the left cpu :
    With the cooler on his place :
    With the red acryl on his place also for the enlargement of the mobo cover :
    And then as last also grey smoke like on the cpu cooler left en on the vga's, is for breading room :
  11. Chiller1
    20 Sep 2010
    for today i quit, tomorrow another day for making something :
  12. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    I got one question why are you using Bitspowers and then some lame plastic conectors???
    It makes me confuse .
    Regarding the modding it´s going on well..
  13. Chiller1
    20 Sep 2010
    the plastics fittings i use because i go sub-ambient temps with this cooling,
    to prevent outside the isolation as much as possible condensation.
    plastics also isolates a little bit against metal, and therefore keeps a few 1°C colder on my liquid.
    The BP connectors i use because i need to pull my tubing tru the alu plate and this is a nice way for it
  14. Chiller1
    20 Sep 2010
    here are some new pics, with a little modification on case, and did some fine work :
  15. zombo
    zombo DOWN UNDER
    5 Nov 2010
    Wow this build is awesome! How long did it take to make the 90 deg connectors? Sometimes I wish mobo manufactures just had the atx power on the back of the mobo lol
  16. Chiller1
    20 Sep 2010
    FOR THE ATX24PIN I DID 4 HOURS ON? AND FOR A 8PIN AND A 6PIN ATX I DID TOGETHER 3.5HOURS ON.
    it's small nasty work lol
  17. Chiller1
    20 Sep 2010
    here are some pics of what i did today, it still needs some work offcourse.
    But now you got an idea how i will do it :
  18. chromespyder
    chromespyder ModANoob
    3 Nov 2010
    Very nice build. Nice details and great design. How long do you think you have left till it's complete?
  19. Chiller1
    20 Sep 2010
    i whant to finish it this year !!!
    this is what i did today :
  20. Yaka
    Yaka Multimodder
    26 Jun 2005
    yep preety nifty mod cant wait for more updates
