News Chip flaw delays Marvell SATA 6Gb/s launch
Discussion in 'Article Discussion' started by CardJoe, 17 Jul 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. _DTM2000_
    _DTM2000_ Minimodder
    9 Feb 2005
    I thinks it's good that Marvell are taking the time to fix the issue but really PATA shouldn't have been part of the design anyway, it's way too old now and the number of people that would want to buy a bleeding edge motherboard and then use ancient drives with it must be tiny. They should have ditched PATA from the start and saved time and R&D costs. We would have had SATA 6Gb/s by now if it wasn't for this.
  3. Goty
    Goty Minimodder
    13 Dec 2005
    Two words. Optical drives.
  4. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    3 words:
    SATA optical drives.
  5. WhiskeyAlpha
    WhiskeyAlpha What's a Dremel?
    5 May 2006
    LOL, exactly what I was thinking.
    I suppose that there's probably more people using PATA optical drives still than PATA hard disks these days but as suggested previously, who buys a top end mobo with SATA-3 capabilities and then kicks up a stink because they need to shell out £15 for a SATA optical drive?
  6. GFC
    GFC What's a Dremel?
    7 Nov 2008
    My 2 cents: scre* PATA, who uses that anyway? Go sata go!
  7. robyholmes
    robyholmes I'm under your desk...
    17 Jan 2008
    SATA optical drives are like £15! Come on! We don't need PATA
  8. Goty
    Goty Minimodder
    13 Dec 2005
    Yeah, but why spend the extra cash when I can keep my perfectly capable drive that I've got right now? Plus, those £15 are usually some loud, low-quality pieces of junk.
  9. Boogle
    Boogle What's a Dremel?
    8 Mar 2002
    I've had expensive optical drives, and cheap optical drives. The noise didn't track with cost whatsoever, even the build quality didn't track with cost. I've got a cheap Samsung drive that's been flawless for years while a more expensive NEC drive is no longer able to burn a reliable DVD disc.
    It may have been true that an expensive CD-RW or DVD-RW drive was better (due to a larger buffer) but now that under-runs are both less likely to happen and no longer an issue you can get a cheap drive and no longer worry.
    Must say though, using SATA drives has improved both the aesthetics and airflow of my case. Must say that ever since SATA optical drives came out I've never wanted a mobo with an IDE or floppy connector - it takes up room and means really rubbish chips end up on the board *cough* jmicron *cough*. Drop PATA/IDE and save a few pennies on the board I say!
  10. billysielu
    billysielu Minimodder
    12 Jun 2008
    I honestly didn't know what PATA was until reading this.
  11. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    Yay. I'm all on for dropping PATA completely.
    If people need it, then they can get an add-in PCI or PCIe card.....
    The floppy and IDE connectors should have gone with the new sockets, AM3 and 1366/1156...
  12. joe-amnesiac
    joe-amnesiac CPC emigrant
    23 Apr 2009
    All well and good, but I'm assuming this is PATA functionality over the SATA connector and cables. Rather than the old IDE connector I think some people are rallying against here.
  13. j_jay4
    j_jay4 Minimodder
    23 Apr 2009
    +1 for dropping PATA
    Having both also lengthens boot up times too.
  14. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Use uses PATA any more? Maybe the odd person with an old ROM drive. Seeing as they can be picked up for less than £20, I'd say ditch PATA all together on new motherboards, that and the floppy connector. That would also help with motherboard layouts.
  15. l3v1ck
    23 Apr 2009
    That should have said Who Uses.
  16. MMerc
    MMerc What's a Dremel?
    17 Jul 2009
    What people don't realize is that a ton of SATA optical drives still use the PATA legacy interface over SATA cables.
    If PATA were dropped from the spec, all of a sudden your SATA optical drives you thought was future-proofed would become defunct.
  17. wharrad
    wharrad Minimodder
    26 Jul 2003
    How about just including a PATA -> SATA adaptor in the bundle with the motherboard?
    I'm sure they used to around 2002 or so, there's a box full under the spare bed here.
    Gooooo on, ditch PATA and use the space for something shiny!
  18. InSanCen
    InSanCen Buckling Spring for life
    30 Mar 2005
    Somehow, I don't think they heard you.
    It's PATA Compatibility mode people, the Physical PATA is usually handled by a seperate chip anyhow's
  19. l3v1ck
    23 Apr 2009
    Doh, I thought the chip controlled the SATA and IDE ports. My mistake.
  20. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    there is no need to support pata just like there is no need to support floppy slot or lpt1 serial ports, ugh come on people get with the times lol.
Tags: Add Tags
