Cooling Chipset coolers for a 7800GT
Discussion in 'Hardware' started by Twinsen, 30 Oct 2005.
  1. Twinsen
    Twinsen What's a Dremel?
    28 Aug 2003
    I'm planning to water cool my 7800GT, but would like to use my Polarflo Universal GPU cooler, and I was wondering if there was any good chipset coolers designed for the 7800GT?
    Something of a one-piece nature preferred.
    Thanks :thumb:
  2. Hans Voralberg
    Hans Voralberg What's a Dremel?
    12 Mar 2005
    Alphacool and Aquacomputer have the one-block design for it. Try to have a look on their site as i dont have a link :D
  3. Mister_Tad
    27 Dec 2002
  4. Twinsen
    28 Aug 2003
    Thanks guys, but before I spend 125 bucks on a full NV-78 cooler, I want to see if there are any good passive coolers for the memory only so I can still use my current GPU waterblock.
    Something like the copper memory to this one for the nVIDIA 6 series:
  5. Firehed
    15 Feb 2004
    Well the 7800GT has the same ram layout as a 6800GT/U so if you can get that ramsink, it'll work. Not having used one I can't say for sure, but the 6800GT at least would let you leave the stock ramsinks on and fit a waterblock just to the core.
  6. AWACS
    AWACS What's a Dremel?
    10 Jun 2005
    I belive that ramsink is from the stock cooler... I've seen similar designs on nvidia cards before
  7. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    a GT doesn't come with a separate ram cooler as shown above... only the GTX does.
  8. c.u.later
    c.u.later What's a Dremel?
    16 Apr 2005
    just get a few ramsinks and a dangerden maze4 GPU to cool it, unless the ram needs cooling.
    c.u.later
  9. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    That ramsink in the pic doesn't come with the stock 6800 or 7800 coolers. It's way prettier than the stock ones.
    I would suggest finding some Tweakmonster ramsinks. Glue them on with Arctic Silver adhesive, and they'll keep your ram nice and cool.
    And, both the GT and GTX have one-peice GPU and ram coolers. The 6800 GT and Ultra have seperate coolers which should fit a 7800 GT/GTX, but they'll probably need airflow to be cool enough to work.
  10. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    The ramsinks and waterblock pictured above is a package deal from coolermaster. The water block and ram sinks come in one kit and are quite cheep actualy. I belive less than 30bux for the unit. You could buy a regular maze4 gpu block and buy the coolermaster setup and use the sinks from the package. Would be cheeper than a 7800 block.
  11. Techno-Dann
    22 Jan 2005
    Nice... If I had a 6/7800, I'd be getting one of those. As it is, my X700 already has ramsinks.
    Maybe when I upgrade...
  12. Twinsen
    28 Aug 2003
    Thanks for the help, I've ordered the coolermaster set. I'll repost if it works one way or the other.
  13. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
