My motherboard has provides no bios adjustment for the chipset voltage, assuming that when overclocked this is being undervolted could this be causing instability? Thanks
yes, it probably would or refuse to boot if u serious oc. try to update the newest bios from your mb website and made sure following the instruction properly. good luck
I have the newest bios, I'm just trying to identify what is holding back my o/c as I don't think it's the memory and the chip (according to ones made in the same week) should o/c higher thn it is. Thanks for the advice though
Have a look round for instructions on a voltage mod for your mobo, bound to be someone out there who has done it.
