Graphics Choosing a 7950 - which one?
Discussion in 'Hardware' started by Picarro, 11 May 2012.
  1. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Hi guys
    Can you help me choose between these three graphic cards?
    The Asus DCII 7950 Cu-edition
    http://www.edbpriser.dk/grafikkort/asus-hd7950-dc2-3gd5-3-gb-id-6560758.aspx?q=7950
    The Gigabyte GV R795WF3
    http://www.edbpriser.dk/grafikkort/gigabyte-gv-r795wf3-3gd-3-gb-id-6560827.aspx?q=7950
    Sapphire Radeon HD 7950 OC
    http://www.edbpriser.dk/grafikkort/sapphire-radeon-hd-7950-oc-detailsalg-3-gb-id-6553923.aspx?q=7950
    Which one would be the best for QUIET performance? Clockspeeds I don't give a damn about - I can clock it myself.
  2. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    I'd personally go with the sapphire. they're supposed to be very quiet even on the stock fan profile when oc'd as far as you can push it.
  3. Picarro
    9 Jun 2009
    Yeah I was just wondering about the cooling desing of the cards. The Asus has the triple slot cooler, which should make it better, but would suck for Xfire as it won't fit my motherboard. The Gigabyte on the other hand has 3 fans which would make sure that each fan has to move slower to move the same amount of air.
    Then theres the Sapphire, where I simply relies on the fact that the company seems to get great reviews.
  4. The_Crapman
    5 Dec 2011
    I've read reviews on all these and all are supposed to be quiet, but unless you can find a review with all 3 in or 3 reviews comparing each combination of 2, there's no sure way to find out which is the queitest. Also the sound will vary from case to case and the combinations of case fans. They're all sure to be quiet, I wouldn't go for the asus due to the 3 slots it takes up and would take the sapphire over the gigabyte on ppure asthetics. However with the giga having longitudinal heatpipes and pyramis shaped fins for less turbulance, it would probably be the quietest.
  5. Picarro
    9 Jun 2009
    Yeah, the Gigabyte is fugly but quiet, and the Sapphire just looks a lot nicer but I don't have a case window.. Decisions decisions..
  6. mav2000
    mav2000 In Training
    16 Oct 2010
    I personally think you would be better of with a 670, atleast the reviews seem to be great and I guess it would probably be cheaper as well.
    If you really want to with with AMD this time around, then I prefer Sapphire and Asus.
    BTW, before anyone flames me on mentioning the 670, I have been and continue to be a long time user of their products.
  7. Picarro
    9 Jun 2009
    Yeah but I want my new GFX for D3 by wednesday. Not sure the 670 will be available before then.
  8. The_Crapman
    5 Dec 2011
  9. Ivoryspike
    Ivoryspike Air Cooled
    11 Jan 2010
    Hey Picarro,
    If you're going for a 7950, watch out when buying the Asus cu ii; they have used an old cooler recycled from the previous gen and some of them out there have problems. I got one because I found it at a very cheap price, no problems here, 29c idle 56c load and quieter than my case fans.
  10. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
  11. Picarro
    9 Jun 2009
    Oh the 670 seems might tempting, but I've already increased my budget from 7870 territory to 7950 territory.. For surround gaming at 5120x1200 I'm not sure if a 7950 would suffice. I'm just leaning more towards AMD as their Eyefinity technology is a bit more mature.
