Graphics Choosing a GPU on a Budget
Discussion in 'Hardware' started by Bituser, 27 Aug 2011.
  1. Bituser
    Bituser 64 Gigglebytes
    13 Aug 2011
    Hi,
    I am trying to choose a GPU for my next build. I'm trying to stay under $350, but if it is really worth it I may go higher.
    I have being strongly considering the Sapphire HD6870 because it appears to have great performance for the price. It will be used for Crysis 2 on high settings at 1920 x 1080 and HD video encoding. Also, in case it makes a difference, the case will be an Antec Nine Hundred Two v3.
    I would prefer to purchase it from the below shop:
    PB Tech NZ Graphics Cards
  2. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    I had a 6870 for a while. I played at the same res at high settings and was seeing about 40-60fps in Crysis 2. Bad company 2 achieved about 70-90fps. This was using an i3 540.
    What cpu are you going to use?
  3. Bituser
    13 Aug 2011
    I'm going to use a Core i5 2500k. This may be a dumb question, but is the game playable at 40fps?
  4. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Dude, try ascent.co.nz as well, free shipping, reliable.. then again PBTech is just down the road for me. PB's has excellent RMA as well..
    Anywho:
    In your price range you can choose 6870 or 460/560..
    http://www.pbtech.co.nz/index.php?z...ire-HD6870-1G-GDDR5-Video-card-Dual-link-DVI-
    http://www.pbtech.co.nz/index.php?z...GeForce-GTX560-1G-PCI-E-Video-card--Dual-DVI+
    http://www.pbtech.co.nz/index.php?z...GeForce-GTX-460-SuperClocked-Video-card---1G-
    See here for theoretical comparisons:
    http://www.hwcompare.com/11005/geforce-gtx-560-vs-radeon-hd-6870/
    http://www.hwcompare.com/8240/geforce-gtx-460-1gb-vs-radeon-hd-6870/
    Looks like the 6870 is the best bet, better cooler too.
    EDIT: 40 fps is playable. generally 30+ average fps is a good margin
  5. Elton
    23 Jan 2009
    I'd aim for 60 in BFBC2. Its got some odd stuttering issues.
  6. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    I run a 6870 at 1920x1080 and with Crysis 2 (I keep V Sync enabled) I get 40-60FPS with DX11 enabled, High Res Textures disabled, most settings on Extreme apart from Post Processing which is Very High. Ultra being the max of course.
    For what you are looking at it sounds about right.
  7. Nealieboyee
    14 Aug 2009
    You'll get 40fps in Crysis 2. Almost guaranteed.
    In Bad company 2 you should get at LEAST 50-60fps.
    Edit:
    Read the description in this vid. He's using a 6870 and gets between 40 and 70fps. God i miss my 6870...
  8. Bituser
    13 Aug 2011
  9. confusis
    5 Jan 2006
    Take the cheaper one I'd say. Cards seem pretty much identical bar coolers. the vapour-x and the other fan (not squirrel cage style) one should be much the same
  10. zulu9812
    zulu9812 What's a Dremel?
    21 Oct 2010
  11. confusis
    5 Jan 2006
  12. zulu9812
    21 Oct 2010
    Yeah, that's the same one
  13. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    i'm no genius on american pricing but they all seem very expensive?
  14. confusis
    5 Jan 2006
    Thats because it isn't american pricing. We're working in New Zealand $. :read:
    (approx 0.83 USD to 1NZD, and our prices are inflated a bit as we're at the bottom of the world.
  15. Aracos
    11 Feb 2009
    That'll be why then!
  16. David164v8
    David164v8 Minimodder
    29 Aug 2011
    6870 is a pretty nice card and in crossfire they are really, really fast.
