Chrome crashing
Discussion in 'Feedback & Suggestions' started by Nikumba, 20 Apr 2011.
  1. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    Not sure if it is my setup, but at the moment when browsing with Chrome I get the aww snap something went wrong screen when browsing the site, and have to reload.
    I have yet to try at home as I am in work, but being a sysadmin I am not constrained by any policies.
    Kimbie
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    chrome here, all fine. disable extensions one by one?
  3. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    Snap, Chrome perfect here. I use no modifications or extensions.
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Behind a proxy?
    Is there an http error code?
    ISP?
  5. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Chrome virtually never crashes for me, are you running the latest version?
  6. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Not sure if it's related, but I'm having all sorts of problems with the site on Opera 11.1. Getting repeated errors about "Shockwave flash plugin failed, Opera needs to re-start". When it tries to re-start from where it was it immediately crashes again with the same error. Must have happened 10 times in the last half-hour. I've also had this problem with my home machine, same browser, different OS.
  7. ZthDimension
    ZthDimension Zth
    21 May 2009
    I to have been having issues with Opera 11.1 as well today, had numerous crashes whilst browsing BT. Haven't quite reached 10 in half an hour but it has certainly been crashing fairly often.
  8. Cthippo
    7 Aug 2005
    I think it's that Darkspore banner, but can't be sure.
    Switched over to my backup browser, Chrome. So far so good.
  9. Jamie
    12 Mar 2001
    I'll have a look at Opera but if it's the adverts there isn't much I can do about it.
  10. Cthippo
    7 Aug 2005
    Hmmm, no more darkspore banner, no more crashing. problem apparently solved.
