Modding chrome spraypaint
Discussion in 'Modding' started by malcs, 9 Jun 2003.
  1. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    how long does chrome spraypaint take to dry????
  2. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    It would all depend on how thick the layer is really, also what the conditions are, ie. is it warm and sunny outside.
    I've used chrome spray paint before on some fan blades and it did take longer than your average paint to dry, just 'cause it's thicker I guess.
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    I'd leave it at least 12hrs, that way you know its going to be dry.
  4. malcs
    24 May 2003
    lol yeah it says on the can 4 hours i think i will leave it 6 to be sure to be sure :D
  5. thedevilspride
    thedevilspride What's a Dremel?
    27 Aug 2002
    On mine it says 1 hour, but after 3 it was fully dry
  6. malcs
    24 May 2003
    oh cool :) left it for 8 hours in the event
    pretty dry though :D
  7. couzo
    couzo What's a Dremel?
    26 Apr 2002
    where did you get this spray paint? And you got any pics of the results?
    Thanks
  8. malcs
    24 May 2003
    i most certaintly do!! just click on the Budget Mod link in my sig -- it is on the last page :D
  9. Pug
    Pug What's a Heatsink?
    16 May 2002
    I need to do a few more coats and a clearcoat on top yet but here's my out of the can result after one relatively heavy base coat with Simoniz Chrome Spraypaint on my modded Dragon bezel.
    Hopefully it'll polish right up when I'm done. :)
    BTW - I just found a Product Recall on some of this stuff, so if you get some, check the batch number. :nono:
  10. Der Me!$ter
    Der Me!$ter What's a Dremel?
    14 Sep 2002
    I used chrome spray paint and it did not dry, even after a few weeks! I found that sealing it with clear paint (ahhh... what's it called??) was the only way.
