Cif Cream, other bleach- Carcinogenic?
Discussion in 'Serious' started by Cptn-Inafinus, 30 Apr 2009.
  1. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    Just a quick question that's been concerning me somewhat. I've been working as a part time KP for a around a year now, constantly exposing my skin to Cif Cream and other scary bleaches for cleaning up. I recently read that many of these cleaning agents may be quite potentially carcinogenic. After having a little search around and checking the bottles for any warnings I've found nothing, but I'm really un-convinced.
    I really should start using gloves, but I find them restrictive and irritating. But I guess no hands could be worse... Maybe I'm just being hyper paranoid.
    Thanks chums :)
  2. Major
    Major Guest
    You could wear those really thin elastic gloves like Doctors etc wear?
  3. hitman012
    hitman012 Minimodder
    6 May 2005
    I doubt that any of them are strongly carcinogenic, but chronic skin exposure to chemicals like that isn't ideal. Buy a few packs of latex/nitrile gloves - they're thin and shouldn't impede your movement.
  4. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    Kitchen Patrol?
  5. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    Obviously a nut
  6. uncle_fungus
    uncle_fungus P/T Folding@home developer
    27 Mar 2009
    Risk assessment produced by Association for Soaps, Detergents and Maintenance Products for Hypochlorite
    Neither Cif cream nor bleach are carcinogenic, however bleach is a strong oxidising agent. Judging fom the ingredients of cif cream, it is mostly an abrasive (Calcium carbonate).
    5-10% NaClO (hypochlorite, bleach) is classed as an irritant.
    >10% NaClO is classed as corrosive.
    At the concentrations you're likely to be dealing with, latex/nitrile gloves have a breakthrough time of at least 8 hours, a pair of marigolds would be even longer. Breakthrough time being the time taken for the bleach to fully penetrate the material.
    Simply put, if you're using bleach or other abrasive detergents the recommendation is to wear protective clothing (gloves) to avoid (reversible) irritation. Since latex/nitrile gloves offer adequate protection with little to no restriction, I suggest you use them.
  7. wgy
    wgy What's a Dremel?
    28 Jul 2008
    kp = kitchen porter ..right?
    i was a kp then waiter and also used alot of wacky industrial hotel cleaning products for about a year and a half. i never wore gloves and didnt really notice any effects.
    but, i would take uncle_fungus's advice, espeically if you have sensitive skin.
  8. ufk
    ufk Licenced Fool
    3 Jan 2004
    If you're really worried about it here's the COSHH sheet for Cif cream
    http://www.greenham.com/datasheets/508364.pdf
    Your employer should have a copy of COSHH for any chemicals you use on site, I know I get enough phone-calls for COSHH data at work from our customers
    NB I work for Greenham's parent company.
