Case Mod - In Progress [CiP] Silencio 550 MbK
Discussion in 'Project Logs' started by kier, 27 Feb 2012.
  1. kier
    kier -----------------
    1 Mar 2011
    De build Silencio 550 MbK
    I’ve made this build for a competition started November last year thanks to Coolermaster and MSI
    Now the competition has ended I want to share it wih you guys. A nice little budget pc with the beautifull Cooler Master Silencio 550
    The hardware:
    Motherboard: MSI Z68A-G45
    GPU: 2 X MSI N550GTX-Ti Cyclone
    PSU: Coolermaster Silent Pro Hybrid 1050W
    CPU Cooler: Zalman CNPS8700 NT
    RAM: Corsair 4X 2GB DDR3-1600
    And various other products as the build progresses
    the beginning : Sketchup design
    Outside:
    The inside:
    And thanks to this design ................. it gaves me access to the next round :)
    Shortly after that I got a pretty comprehensive package
    The package for the second round:
    Very extensive, I can definitely make something nice with this
    First the Cooler Master products:
    The case where it is all about .......... Cooler Master Silencio 550
    Out of the box
    All beautifully black
    Box with tools and other stuff
    Coolermaster has also provided 3x SickleFlow 120............Red, Green and Blue LED Fan
    Not gonna use them, but they came with the contest
    The CPU coolerr: Hyper 612S. Not gonna use this one….sorry ;)
    And a great power supply, the Cooler Master Silent Pro Hybrid 1050W
    All modulair
    I really like the colors from this PSU
    The fan controller
    The cables from the fan controller
    Enough modulaire cables
    The products from MSI
    The motherboard: MSI Z68A-G45 (B3)
    En last but not least the MSI N550GTX-TI Cyclone II IGD5
    So here we go ;)
    Stripped the case and this is whats left
    Marked the top for the two fans
    Sawn the top
    Yeh, it fits 
    Next job the front
    Marked
    Sawn it
    Isolation still intact
    Next round
    Placed two fans for measuring
    Placed it back and powered it up
    First sawn a piece of green 5mm acrylic
    Whitch is gonna be placed like this
    After that adjusted the rad grill
    And cut and bent 2 aluminum strips
    And slid it under the grill
    Like this
    I did not quite align this with the acrylic, because I want some light reflected to the green acrylic
    I also have made the side panel for this ive cut a square in the existing panel.
    Custom made transparent acrylic panel
    Around the transparent acrylic a small edge UV green 5mm acrylic
    Both acrylic pieces attached to existing
    Inside
    And placed it to see how it looks. Think it looks nice with the Nanoxia fans
    Still isnt finished
    Cut another piece of 1mm black aluminum
    This is gonna be placed again on the green and transparent acrylic and past it on all sides 5mm space left, so the green acrylic is visible
    Inside
    And put it all togheter
    That's it for now!!!
  2. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    First!
    Good God, Kier... I swear to the heavens: you MUST be a machine!
  3. kier
    1 Mar 2011
    Lol, thanks Nutman
    Btw. received the result of the contest today..... second place :) :) :rock:
  4. l3p
    l3p www.^.nl
    1 Nov 2010
    Congrats Kier!!!
    The judges must have been crazy :p
  5. KidMod-Southpaw
    28 Sep 2010
    Horray! More of Kier's best case brand!
  6. kier
    1 Mar 2011
    Hmmm, I wonder.....:naughty:
    Thanks Kidmod :thumb:
  7. RedManc
    RedManc New Member
    30 Jul 2011
    Thats it? Put a little effort in man :p
  8. kier
    1 Mar 2011
    Your right RedManc, I will not sleep anymore and finish this build ;)
    Update!!!
    Spent some time to do the midplate / psu cover. First made ​​an iron bracket and covered with (what else) UV green acrylic and black acrylic
    A small hardware update. Bought myself a nice cpu cooler in the style of the MSI Cyclone GPU
    Next to the MSI Cyclone
    And placed everything. There's gonna be a second Cyclone
    Combination is pretty good I guess;)
    To stay in the line of the sketchup design I sawn a piece ​​of UV green acrylic and paste it with black vinyl and placed it where the HDDs will come
    Cut some rectangular shapes and covered it with matt black vinyl
    And after cutting, pasted and filed... the end result
    To be continued!!!
  9. Nutman
    21 Oct 2008
    Very cool - how did you make those rectangular pieces stick to the HDD cover?
  10. kier
    1 Mar 2011
    Just with my fretsaw, nothing special
    Update!!!
    Been busy with the outside: the top of the case.
    I used a piece of UV green acrylic
    And sawn it
    Also cut a piece of black aluminum, A little smaller than the acrylic piece
    And paste it on the acrylic
    I have sawn a piece of mesh for the opening on top, below this there will be 2 Nanoxia fans just like the sketchup
    And I did the other side of the case. For this I have marked another piece of green acrylic
    Sawn it again
    I want the looks like the other side, so I have sawn a piece of black transparent acrylic and put it in the Green. Ok its a fake window but looks good ;)
    Cut a piece Aluminum again
    And the other side with the fake window
    The outside is almost finished, next is the the casbadge from Coolermaster and MSI
    For the case badge I have again called on a good friend Pascal ... thanks man
    He has some connections with the best advertising company from my town and perhaps the Netherlands ;)
    Ladies and gentlemen of Letterop thank you for this wonderful piece of work
    Pasted the sticker gently on a piece of 3mm green acrylic
    And enlighted from the back it looks like this
    Very good looking casebadge
    To place this on the front I have made a bracket ​of aluminum
    And a piece of 5mm green acrylic sawn and drilled
    And made some oblique and curved corners
    And tapped M3 holes in the green front panel
    Placed the bracket
    Mounted the piece of 5mm acrylic
    And just like the sketchup: the "case badge"
    Need to paint the radgrill black again
    Used a glowpad for this to enlight it
    Power on
    And placed the acrylic back
    And power on
    Casebadge on it
    And again power on
    Total shot
    And a night shot
    Still some small things to do for the cover, but im getting there :)
    Grtzzz.
  11. Black_Mummy_DK
    Black_Mummy_DK New Member
    3 Oct 2011
    i must say this is actually looking really really good... :D
  12. Nutman
    21 Oct 2008
    Very nice backlighting for the logos.
    Did you manage to bend the aluminium without destroying the anodizing on the bends?
  13. kier
    1 Mar 2011
    Yes, just a little bend will do
  14. kier
    1 Mar 2011
    Update!!!
    Hello my modding friends, this time i have made a cover for the power suply
    Just like the sketchup sawn some small slots for the air
    After some sawing and filing
    Also made a small piece of green acrylic to close the airslots in the door
    Sawn a piece to cover up the 5.25 bay
    Placed like this
    And leave some space for the dvd writer and cables
    Removed the protection sheet
    Used some black vinyl to get the same looks as the other pieces
    And added my own logo
    Behind this another glowpad
    And another piece of acrylic for the slot mechanisme
    Also pasted with black vinyl
    Did some last stuff to the front and inside, like placing some smd strips
    And again used some Vinyl on the cpu cooler
    Sleeved some extensions for the power GPU's
    And the 24 pins
    So the build is almost finished, just some small things like placing a second GPU.
    And then...... the final pictures
    Placed the second GPU
    Power up some extra light
    Painted the SLI bridge
    That makes a lot of difference
    Placed the side panel, and again some pics
    Final pics coming up ;)
    peteski likes this.
  15. peteski
    peteski long live the pc
    8 Jun 2011
    kier i absolutely love your builds what you do with acrylic amazes me and inspires to start my own mod. keep up the good work and +rep to you :rock: :rock: :rock:
  16. kier
    1 Mar 2011
    Thanks for the comment and rep my friend ;)
  17. SilveR_172
    SilveR_172 Member
    24 Nov 2011
    Brilliant mod mate loads of projects are coming out of the kier Modding factory right lol
  18. Nutman
    21 Oct 2008
    Yes, this is very impressive. I love that CPU cooler - it looks kind of like the Ironman chest-thingie. ;)
    Kier, where did you buy those glowpads and how much are they?
  19. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Good job. I like this.
    Great color scheme.
  20. The Crusher
    The Crusher New Member
    5 Mar 2012
    Nice mod :) i like it :)
