Hey all you electronics gurus, need a hand on where to start with this one. I have a non-dolby-DTS 5.1 optical signal coming into an amp that im building, the amp is only 3 channel (2.1) but i still want it to be able to play from non-dolby TOS sources. I say non-dolby because i know dolby encodes its DTS otpical outputs and its a bugger for a homebrew application that I can build to decode it all again. If anyone knows of an easy way to do this though, please let me know. So yeh, the pre-amps can deal with pretty much anythig as im building/have built from scratch. Line-level would be perfect for what im working with. All i need is a way to convert optical into a line level analogue signal. Help please, cheers, dave
I looked into this several years ago and it's very complicated. You can't do Dolby/DTS because you need a license. However, you've said you don't need that so it's a bit easier. I've just found this DIY decoder project. It looks pretty well explained, except he doesn't mention converting the optical signal into the coax or TTL signal that the circuit requires. You could buy a complete unit to do the optical to coax conversion, or buy an optical receiver and wire it up yourself, which would save a fair amount of money. Have a look at the DIY project and work out how much it's going to cost you. There have been converters in the past (apparently Creative made one, and Toshiba too) but they're out of production. Hope that helps! ch424
Hey ch242, thanks for the reply, yeh i saw that project in my endless searching, that seems to be the easiest way, i've already started drawing the schematic up in Isis 6 for that one, will get it netlisted into Ares by tomorrow, etch it at the weekend and see how it runs next week. Thanks for your help matey
I'd been looking for a while prior to asking on here, the main DAC you can either scrounge samples for from cirrus or farnell sell them farnell code : 1023373 - £1.80 a pop luckily you can buy singularly, lol The CS8414 he uses is now not recommended for use in prjects by cirrus themselves, tis been replaced by the CS8416 Not overly good because i can only find a SMT package in the uk market again, farnell code : 1023451 - over £4 each.... so they are available, just not very readily... or very cheaply, lol
