Case Mod - In Progress CL0S3 IMPACT-Final pics and a closing for this saga
Discussion in 'Project Logs' started by B NEGATIVE, 7 Aug 2013.
  1. skyrip
    skyrip What's a Dremel?
    22 Jun 2013
    5mm is definatally to thin to make this big size reservoir, 10mm would most likely be minimum. with some heat and pressure the 5mm plates will definatally deform.
  2. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Pressure is not an issue,7 psi is pretty weak, certainly not enough to blow anything out.
    As this one is watertight,i think frosting or painting the back of the res to tidy it up should work well
  3. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Bad news about the bubbles man :(
    This is why I'm so happy to be pissing around with a PC that costs less than the case you are using haha, as I can make mistakes and just chalk them down to a part of the charm.
    Looking forward to seeing more. Like the res, looks really solid.
  4. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Frosting would look really great, would give it a lovely matte sheen.
  5. B NEGATIVE
    8 Aug 2011
    Im inclined to agree,also im concerned about shooting a colour without a primer...which would show thru at the front. Frosting works on acrylic without damage.
    What I should of done,but didnt trust myself not to splash solvent everywhere,was brush the faces first then fit them.....
    Its not the end of the world tho,it will still do its intended task,I am like the guy that paints the feet of Airfix pilots tho,you wont see them but you will know they are there.
  6. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Looks good imo. Can't really see the issues with bubbles.
  7. Cheapskate
    13 May 2007
    Can you apply a little more solvent in the seams? I know it helps sometimes, but often the air around the edges is common and not fixable. That's why I glue some billets oversize and mill out of the middle stuff.
    Have you thought of making a set of panels to cover the edges?
  8. B NEGATIVE
    8 Aug 2011
    Yeah,I tried that Cheaps,didnt work,its like a fine mesh of bubbles ...water doesnt penetrate,it just looks ugly.
    Im going for a frosted finish instead,It will hide the bubbles like a boss but will still let the coolant peek thru.
  9. B NEGATIVE
    8 Aug 2011
    In other news,the res has been filled to the brim and,in a unscientific test,left outside for 24 hrs in the sun so it gets heated and cooled for some thermal cycle testing.
    Glad to say it didnt leak at all and I am happy for it to go in.
    A good shot showing the 5mm thickness of the front panel.
    Overall im stoked with it,Justin and Shaun have done me proud with this one. They copied my drawing to the letter and it has come up trumps.
  10. Hukkel
    20 Dec 2012
    It looks smexy!
  11. AlienwareAndy
    7 Dec 2009
    Yeah man I like :D great work !
  12. dietje1908
    dietje1908 What's a Dremel?
    12 Jan 2009
    is it possible for the new res to sit flush with the frontpanel ?
    love the colors btw :)
  13. B NEGATIVE
    8 Aug 2011
    What do you mean? The face is flush with the panel.
    In other news.
    Specialtech happy care package has arrived!
    Something new for me,Acousti Acoustipack soundproofing sheets,never used them before and I like to try new things so I thought 'Why not?'
    My eternal favorite,the D5 pump makes its appearance and its the XSPC vario like in my last build,they are so cheap now there is no reason not to get one.
    And.....snake oil.....I couldnt find Ice Dragon in its normal form anywhere so im using this instead,
    Now the sheets are self adhesive and that glue is a grabby as hell so be careful if you choose to use it too....
    Im doing the sidepanels and front panels with it to dampen any panel rattle or noise from inside.
    So,I lay the panel out,cut a sheet to size and then lay it in the panel,pushing the studs thru for the window.
    Lay the window on top,cut round with a sharp xacto knife.
    Then peel off the backing paper and stick down Job done and about half a kilo added to the door. This stuff is a 2 layer construction and weighs a ton!
    I do often wonder how effective this things are,now i will know for sure.
  14. OrangeClockwerk
    OrangeClockwerk Clockwerk Industries
    28 Jul 2013
    Yeah I went with 3/8" (9.5mm) acrylic on my handmade res, it was definitely overkill, only leaks came from being a novice with the acrylic cement. Im going to go with 1/4"(6.35mm) acrylic on my current build but I am going to router grooves where the panels glue together for a better and stronger seam and no leaks. Nice work on this B NEG, I like this build a lot, great mods , cool color. Cant wait for a finished product =D Cheers!
  15. B NEGATIVE
    8 Aug 2011
    I totally recommend routered edges and wicking solvent weld,it all becomes one with no interface bond layers
    I finished frosting it and im happy with it now,i did derp a little and weld a piece the wrong way round tho I noticed....
    Ah yeah...my derp is......
    Idiot......
  16. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    Looking sexy!! :eeek: I'm liking the paint. So sick! And water cooling the fan controller? :jawdrop: Sweet! :rock: Definitely subbed. Keep up the awesome work. :thumb:
  17. imersa
    imersa Parvum Princess
    9 Apr 2009
    Beers at iSeries woooo
  18. montymole
    montymole Rigid Tubist
    24 May 2010
    dam nice build look forward to seeing this complete
  19. B NEGATIVE
    8 Aug 2011
    Its so close too.....just some interior wiring and the long wait for my active backplate....which is holding me right up as the terminals are different.
    A small update.
    I clear coated the front and res and as you can see,removed the Caselabs logo as it didnt really look right with nothing on the ped..
    And in direct light.
  20. Hukkel
    20 Dec 2012
    That first picture is really nice. Makes it kinda look gunmetal grey metallic with a glossy finish (if that makes any sense).
