Case Mod - In Progress CL0S3 IMPACT-Final pics and a closing for this saga
Discussion in 'Project Logs' started by B NEGATIVE, 7 Aug 2013.
  1. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    I got a new toy...a macro lens. I couldnt help have a play with it and setting up the Phobya RGB light kit...in true Phobya fashion the kit then packed up after about 15 mins of use..and a connector was missing so i could only use 1 of the 2 RGB strips in the top....
    Very disappointed in YET another Phobya product dying almost immediately.....
  2. B NEGATIVE
    8 Aug 2011
    A little over spray to tackle but on the whole...looking ok.
  3. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Looking very nice man :)
  4. B NEGATIVE
    8 Aug 2011
    Still a long way to go yet,PARVUM are at work on the res,got to get a card yet,seen a nice 780 Classy going cheap so that and an.......EK.......block will probably feature now.
    Lutro Customs are supplying the braid,terminals,plugs and tools,the BeQuiet PSU will look very nice I think,I hate sleeving but its got to be done. :thumb:
    I really should gets parts all together at the beginning but i like to take my time and scout for the bargains...:duh:
  5. Hukkel
    20 Dec 2012
    Haha always the hate for the sleeving work :D
    It is a lot of work but when done right it is the cherry on top of the project.
    It can make or break a mod imho.
    Good luck :thumbsup:
  6. lowfat
    lowfat Active Member
    4 Jul 2013
    Wholeheartedly agree. :D
  7. B NEGATIVE
    8 Aug 2011
    Should of guessed the sleeve police would turn up on the mention of it......Lowfat especially....:hehe:
    Got a very large thick cotton white backdrop for the pics...looks a bit better...
    The braid and terminals from Lutro0 to start the custom harness are on its way...its in Chicago! Woooooot!
  8. Asouter
    Asouter --------
    18 Jan 2012
    Looking good BNEG, The white detailing really breaks up the case ... good to see some progress :thumb:
  9. B NEGATIVE
    8 Aug 2011
    Thanks Asouter,it needed something otherwise it was just going to be a bland box.
    Got a white pearl to shoot over the logo but the lines are staying white,then I have to run a 2mm black line around the lines and logo to sharpen it up.
    Also debating ditching the IO panel and having flat plate,use the Aquaero for the on/off function instead of the capacitance switches.
  10. Asouter
    Asouter --------
    18 Jan 2012
    I used the Ice white (with blue pearl)... and it's a very subtle effect, almost to the point where it's barley noticeable. If you're looking for a bit more pop I'd suggest a silver flake over the white. It should blend in with the white without being too OTT.
    You'll see what I mean when you use the pearl :)
    [EDIT] Cheeps is spot on with the finger marks on the on/off button
  11. B NEGATIVE
    8 Aug 2011
    Yeah,the moment i did the buttons, i knew it wasnt going to look good...sometimes you need to try this stuff first tho.
    I want a subtle effect,just so it pops at the right angle rather than a heavily reflective look. Im not sure if flake will run thru my airbrushes anyway,what nozzle size does it need?
  12. hero1
    hero1 New Member
    18 Oct 2013
    I def will drop by when I come around. I am aiming to be there sometime in September this year or early 2015:clap:
  13. hero1
    hero1 New Member
    18 Oct 2013
    You are making great progress here. This is looking good:thumb:
  14. B NEGATIVE
    8 Aug 2011
    Thanks! RAM has been ordered up and......
    I would like to thank Mike @ Lutro0 Customs for the PSU kit for the custom harness for this build,im seriously impressed with the quality! I wish i had thought to get a new PCI tool,if it matches the rest of his stuff then it should be a winner!!
    Silicone 18AWG is on its way too,going to be a busy week for me neh?
  15. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Make freakin sure you get the right wire in each hole on the connector! I've fried computers that way!
  16. B NEGATIVE
    8 Aug 2011
    I test continuity against the stock cables before they ever hit the rig. Custom harnesses...Cheesecake
  17. B NEGATIVE
    8 Aug 2011
    New res design for the S3,integrated light boxes at each end.
    All glued construction and just a cut out job from 10mm acrylic,much simpler and goes a lot better with the rig.
  18. B NEGATIVE
    8 Aug 2011
    Finished plumbing the ped...
    Mouse gynacology at its finest and as tight as a nuns chuff
  19. lowfat
    4 Jul 2013
    :hehe: at analogy
  20. Hukkel
    20 Dec 2012
    Looks more promissing everytime man :)
