clamp size
Discussion in 'Watercooling' started by neonlights, 2 Sep 2010.
  1. neonlights
    neonlights What's a Dremel?
    14 Jul 2009
    looking on the site i was wondering what size i clamps i would need for a 3/8 barb.
    fearron
  2. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    depends on the tube you use but normally 13-15mm if your looking at the spring clamps
  3. neonlights
    14 Jul 2009
    i think its 3/8id 5/8od but thanks for your reply :)
