Clan[42]project<CONTESTS WON!! :D >
Discussion in 'Project Logs' started by Vazzini42, 11 May 2004.
  1. hmekk
    hmekk What's a Dremel?
    17 Jul 2004
    realy huge and cool project
    very nice
  2. Vazzini42
    Vazzini42 What's a Dremel?
    16 Apr 2004
    thank you :)
    I know the project isn't finished yet but it's getting pretty close to completion.
    Can I ask you guys to please honestly rate my project log/project?
    I gave myself a 4 because i'm proud of it but i can see all the flaws
    Thanks in advance :)
    sidenote: i have ordered another Sony PSone screen to replace the first one it should be arriving soon. I have just recieved my 4 cold cathode tubes from http://www.elwirecheap.com/ along with my slot loading DVD rom from ebay. I should be recieving another box tomorrow (friday) with tons of goodies from http://www.frozencpu.com/
    more on that tomorrow then take it easy
  3. CooLJoE
    CooLJoE Minimodder
    20 Mar 2002
    Looks good. Can't wait to see what becomes of it.
    Not sure on your final plan for the big LCD, but I would remove it from the casing and put just the LCD screen in that front window spot. The plastic will detract from the overall look.
    BTW, can you PM me where you got your Sony PSOne LCD from? I would be very greatful.
  4. Vazzini42
    16 Apr 2004
    ebay boss ebay
    funny thing is I have bought 3 total
  5. Vazzini42
    16 Apr 2004
    Well I recieved my UV reactive Green power supply cover with 80mm fan hole
    the fan is a UV reactive green one with 4 UV LEDs inside with an aluminum mesh fan filter on it
    What do you guys think?
    yes i know the fan is "supposed" to go on the inside not the outside. I did this to help give it more breathing room and help spread UV light around the case better as well as eat up a little bit more room in this big box.
    I think it looks pimp as hell, was easy to install and kinda chear.
    Here's where i got it from http://www.frozencpu.com/cgi-bin/frozencpu/psc-06.html
    Vazz
  6. Tech-Daddy
    Tech-Daddy What's a Dremel?
    8 Oct 2003
    Show off the thing in it's glowy stage bro!
    Lookin purty schweet!!!
    :rock: :rock:
  7. Vazzini42
    16 Apr 2004
    thank you kindly tech-daddy :)
    I see you are in plano texas... are you planning on hitting Quakecon next week?
  8. Tech-Daddy
    8 Oct 2003
    I will be there Friday night and Saturday. I dont think I'll have bling with me, as my # for the byoc is insane!!!
    But, to answer your question, a definitive "Yes"... I will be there! I look forward to seeing this beast in person!
    :thumb:
  9. Vazzini42
    16 Apr 2004
    night time shots as requested...
    mmmmmmm why do i feel like a moth? :D
    Sweeeet ! be sure to say hello :D
  10. Death Reaper
    Death Reaper What's a Dremel?
    27 Jul 2004
    That's a nice PSU, I look forward to seeing the finish of this mod. But the PSU doesn't quite fit the color of the case :/
    Regards,
  11. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    :wallbash: :wallbash: Not another awesome thing to buy online! :waah:
    Paying bills sucks.
    Now, that is one nice looking PSU mod. Cant wait to see it in its home in the case.
  12. Vazzini42
    16 Apr 2004
    The outside of the box is yellow, the inside is going to be green from UV reactive stuff with UV lights and green cold cathodes, then a lot of the other stuff is black or silver. I think you might change your mind with some finished project pics. :D
    Ok picture time....
    I have finished painting, sanding, and polishing most of the parts. I have gona ahead and remounted the visor thingy that was used to protect the front. <PLEASE NOTE THE COLOR IN THIS PIC IS CRAPTASTIC not how it really appears>
    Today I have to go to work and make some money, but hopefully I will have some time afterwards to get more the interior completed.
    Vazz
  13. bootupbuddha
    bootupbuddha grunge modder
    3 Feb 2004
    You know, there is enough room in there to put in a softdrink dispenser. Just think, your mod could pay for itself and you could quit working! err, well maybe not.... never mind :wallbash:
  14. Vazzini42
    16 Apr 2004
    deleted
  15. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    the green PSU is not to my liking but it should work good for what you want it for, and that sux that you can't have just the LCD showing, ah o well, this still should be nice in the end, following this one :thumb:
  16. Sanf0rd42
    Sanf0rd42 What's a Dremel?
    21 May 2004
    trust me, we questioned him about the color-combination, but now that it's all coming together, i see how it's all supposed to work.
    the boy's got some smarts :D
    Vaz said he "wanted people to recognize the case mod from an airplane" ... i think it's bright enough for that ;)
  17. Vazzini42
    16 Apr 2004
    OK, my deadline is fast approaching and I only have 1 day left to finish this box.
    So far I have...
    1) finished the paint and first coat of wax
    2) installed the 4 120mm Thermaltake fans using rubber grommets
    3) installed all the fan guards and filters
    4) installed and bolted in the Uninteruptable Power Supply
    5) added some noise killing foam (yes, this thing is gonna be loud)
    6) glued the control panel for the UPS to the front of the box
    7) attached the side window panels
    8) reassembled the majority of the box (only the top closing mechanism left to attatch)
    9) installed and wired up the 4 cold cathodes (2 12inch green/ 2 12 inch UV)
    I'M SORRY I HAVE NO PICS OF THESE STEPS
    It seems the next pics I post will likely be the final glory pics.
    THINGS LEFT TO COMPLETE IN 1 DAY: (tomorrow)
    1) cut sand and mount 7 more pieces of diamond plate
    2) mount the main LCD monitor
    3) mount the mobo, PSU, and HD
    4) cable management (hide as many as possible)
    5) install Linux
    wow, tomorrow is going to be a LONG day
    Well, if I live through tomorrow, the finished pics should be up soon.
    Vazz
  18. RR5
    7 Dec 2003
    Good luck. You'll get it done on time, watch.
  19. dima y
    dima y What's a Dremel?
    26 Apr 2003
    i have a 24 hours ride to quakecon, with internet along the way. Good Luck, there is no turning back now.
  20. JEEVES
    JEEVES Minimodder
    14 Jul 2003
    Yeah i feel ya, My case is not finished either (black lightning) and i am stuck here at work from 9-9 today :waah:. That means i have alittle over 24 hours to finish my case before quakecon. Hows your case coming? I hope you have more time to finish it than I do.
    JEEVES
