Hi there, My name is Tino From Atipikal designs. I'm writing this buildlog from Canary Islands, Spain. May be my English is not as good as it should, so sorry for that in advance. That said, Time had come to get a new computer so my 11 year old daughter can do her homework and school projects. It was going to be her first computer so I wanted something special as a birthday present so I went for a scratch build computer case. I recently upgraded my workstation so I had some spare parts for the project and only had to buy a few more on line and some others from local suppliers. This is a brief list of them: Pc parts: Asrock am1b-m motherboard. air cooled am1 Sempron 3850 cpu. 12gb Corsair vengance ddr3 1600 mghz. 500Gb Seagate 7200rpm hard drive. Ordered parts: 250W pico psu. AC/DC adapter. 5v usb rgb led strip A3 cast acrilyc sheet Reflective Vinyl sheet Silver Aluminum feet Metal power button: Local suppliers: 500mm x300mm x 20mm pine wood sheet m3 nuts and screws Black Hex Nylon M3 Standoffs. White primer spray White paint spray Fucsia paint spray Cutting Vinyl The idea for the case came from an acrilyc led sign tutorial seen on YouTube, and told myself why not taking that idea for the case, so I bought a pine wood sheet, an A3 cast acrilyc sheet, the led strip, the aluminum feet and some screws and started to design and build the chasis. I cut the three wood pieces as shown, Using my rotary tool, I routed a line along the biggest piece of wood, where I placed the led strip, Screwed the other two pieces leaving room enough to insert the acrilyc sheet between them. Also, I sanded and varnished all wood pieces and finaly, attached the four silver aluminum feet on the bottom side of the biggest piece. That made the basement of the project. After polishing the Acrilyc sheet edges I engraved the unicorn design on it usisn the Dremmel engraving bits Then I placed it into its wooden base, and then I tested the led lights and the edges of the acrilyc sheet and engraved design glowed for the first time as shown. Time now to place the electronic components on the acrilyc.....
The idea here, is to place the motherboard on one side of the acrilyc sheet, leaving the other side to place the 3.5’’ HDD. The motherboard will be placed with its I/O interface oriented downwards so all cables can be easily routed. I drilled the needed holes to attach the standoffs and screws for both the motherboard and HDD, and also an additional hole to pass the sata cables from one side to the other. Once I placed the motherboard, HDD and routed all cables, it was time to prepare the acrilyc sheet that is going to shield the motherboard and its components. For that job, I decided to use a 3mm acrlilyc sheet and four pine wood rods. I cut the rods to 120 mm to work as standoffs for the acrilyc shield, and paint them in white. This is how the acrilyc shield will be installed before cut and paint. After this I prepared the shield by adding some vinyl designs before painting, and cut a round hole at cpu cooler level. I used an aluminum grid to cover that hole. Also I drilled another hole to place the power button I cut and paint a HDD cover aswell with acrilyc, and this is how HDD cover and shield look: Then I set them on their final place: Some more pics of the final result: This is how I gave my daughter her present:
