Cleaning a keyboard :)
Discussion in 'Hardware' started by Mr-IK, 17 May 2007.
  1. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Hey guys.
    This might be a odd question, but i was wondering how you guys cleaned out your keyboards? I'm using a IBM Rapid Access III, standard looking keyboard, but its hard to get between the buttons.
    Perhaps someone have a nice tip for me?
    Greets IK :clap:
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    Compressed air!
  3. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    compressor or pop all the keys out.. just remember to put them in order if you dont have a spare
  4. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    You might laugh, but Custom PC had a mini-article on putting keyboards in a dishwasher to clean them. You need to leave them to dry for 24 hours or so after - and try it on the economy/low heat setting, but it apparently works. I'm yet to try it, so don't hold me to ransom if it ends in tears.
  5. Jipa
    5 Feb 2004
    well if you disassemble the keyboard and pull the electronics out then you can put the entire keyboard to the dish washer. I tend to just pop a few keys away and use a vacuum cleaner at low power. The best advice I can give is not to eat on your keyboard, use the mouse pad instead ;)
  6. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    That's not a bad idea, tbh. I'll definately try it out next time.
  7. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Thank you for the replies, ill try the dishwasher thing aswell :D With an older keyboard first that is.
    Wonder if my laptop would fit in there aswell?
