Modding Clear 120mm fan
Discussion in 'Modding' started by Cyberbob:-), 13 Aug 2002.
  1. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    Does anybody know where I can get a 120mm clear fan.....
    I mean totally clear...
    I know Enermax 120mm Fan has clear blades, but the rest of it is blue.........:idea: :yawn:
  2. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    I don't think anyone makes a 120mm clear fan (that is totally clear). But based on the number of times I have seen the question asked here and other places, I'm thinking if I could manufacture them I could go ahead and retire! :D
    BTW, the enermax clear blade fan also comes in purple (called red) and Globe makes one that is black with clear blades. :)
  3. Cyberbob:-)
    16 Jun 2002
    Do you know if the Globe 1 is available from any UK sites?
    That would match my black case........Might even stick some blue led's in it...:dude:
  4. Deviate
    3 Jun 2002
    Sorry...can't help you there. :( I even tried a google search for them and turned up nothing. I know they can be found in 2 places in the US. BestByte.net and FrozenCPU . But I know that doesn't help.
