Cases Clear (Acrylic) PC Cases?
Discussion in 'Hardware' started by Mongoose132, 4 Nov 2011.
  1. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    I've been looking all over for a clear ATX/Mid Tower clear acrylic case for my next build, all the ones I seem to find have sold out months ago (Like this Sunbeams one, or this one on Amazon.
    I'd love you all forever if anyone knows of anywhere to get one :naughty:
    Want to make a boootiful watercooled thing, with hoses coming out of my ears. :lol:
  2. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    ive found some on ebay heres the link
    Acrylic Case
    Post:1770
    Rep:1770
    :D:D Its just like magic
    LennyRhys likes this.
  3. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    A couple words of caution, acrylic cases are a pretty "specialty" item so be prepared for some complications to go along with the looks. The primary concern, not many reputable manufacturers make acrylic cases. You're liable to get poorly constructed cases and cracked cases if you buy from people who don't have a reputation to worry about. Definitely make sure you're clear on your return policy to watch out for this, your case is entirely clear afterall so every flaw will show.
    Also make sure you can actually do what you intend to do. You're not working with metal anymore, if you need to cut a hole be sure you have the tools and know-how to cut acrylic properly. Will your radiator fit? How will you be securing your pump and res? The last thing you need when setting up a watercooling loop is case problems throwing everything off plan.
    If you've got all of that settled then good luck, unfortunately I can't help with any places that have them in stock.
  4. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    ^ I was looking for one of the sunbeams cases, I used to have one but I dropped it, and like you said, not that durable, smashed into bits :D
    Going to practise a bit again before I start chopping it up, what could possibly go wrong :p
    And thanks for the link flame, I shall keep searching for a while but if I can't find any more I'll take the plunge. :p
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    TBH, you could just make your own :)
  6. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    But mine would inevitably end up looking like a school technology product, with hot glue all over the place and sharp, deadly corners :D
  7. donok
    donok Every Little Helps .....
    16 Feb 2011
    Joining acrylic is pretty easy just use acrylic cement and a syringe.
    The hard work is prepping the edges to take cement.
