Small Form Factor Clear case for Shuttle XPC SB75G2
Discussion in 'Hardware' started by TimmerUK, 20 Dec 2003.
  1. TimmerUK
    TimmerUK What's a Dremel?
    16 Dec 2003
    Hi All i need some help. I am looking at modding my case. I looking for a clear cover for the Shuttle XPC I want to mount a 120mm fan externally to keep the temp down in the case.
    Any ideas of where i could get high quality case....
    Timmer :rock:
  2. TimmerUK
    16 Dec 2003
    Anyone.... anyone..... Bueller.... Bueller....Bueller....Fry.... Fry.....Fry
  3. Sportbilly
    Sportbilly What's a Dremel?
    9 Oct 2003
    I made a smoked plexi cover for a SS40G once, took a few hours with a table saw, hole saw, plexi glue and a heat gun.
    I bent a piece in a U-shape, and then bent the rear edges in like the stock cover, glued some bits into the front and bottom edges to lock under the tabs to hold the whole-shebang in place. Used the standard thumbscrews even.
    Don't know if they're sold anywhere, they weren't when I made mine.
  4. dunkster
    dunkster What's a Dremel?
    5 Jan 2004
    There is a cover called the Clear View available.
    Link:
    I don't know if u can get it anywhere in the UK though.
