Planning Clear glue for acrylic (available in the UK)
Discussion in 'Modding' started by Sir Digby, 18 Mar 2009.
  1. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    I need some clear acrylic glue for my design project at school, in my travels through the forum search and Google I have found Tensol Cement as a possible candidate.
    And it appears that unfortunately IPS Weld-on is not available in the UK.
    So, any other suggestions of glues that I could easily get in the England and that dry clear?
  2. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    i would think any clear drying plastic cement should work just fine. Swing to your nearest hardware store and ask what they have.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Plastic adhesives come in two groups,
    • Ones that dissolve the plastic surface to create a strong "solvent-welded" joint
    • Ones that just hold onto any scratches on the plastic surface and vary from poor to excellent
    Tensol#174; is a solvent-welding type, "any clear drying plastic cement" ain't going to work unless it's a poxy resin.
    Sir Digby likes this.
  4. sixfootsideburns
    6 Feb 2009
    hmm, then i stand corrected. Though i will say i've used plastic cement for small acrylic projects before and it worked just fine... i guess the bonds just didnt need to be that strong
    or maybe im just not remember correctly, it could have been apoxy i suppose
  5. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    I glue acrylic sheets together all the time at work and we always use Tensol, so far I haven't come across anything else thats strong enough. You just have to make sure that your edges are highly polished and that you don't trap any air bubbles in the fillet of glue when you stick the parts together. I'd recommend a couple of test joins before you commit to the final join.
    One thing I did discover is that wood glue(which is basically PVA glue) will stick other materials to acrylic quite well. I recently made a large insulated door for a chilled glove box out of two sheets of acrylic and some expanded polystyrene. It stuck together really well, the only thing is that the glue dries to a translucent film although it didn't matter in this situation.
  6. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Another tip, is to get the surfaces very wet and put them together, this will then show you where air could be trapped during the glueing process.
    In the past i have used small amounts of acetone to bond acrylic together, and it results in a clear bond, but after a few months i found it turning yellow..
    Dont dismiss are friend super glue, when bought by the bottle rather than tube it is very useable, bonds extremely well and when prepaired right can offer a clear bond.
  7. Sir Digby
    18 Jan 2009
    Ok, thank you everyone for the advice and tips :thumb:
    I assume that I need to use a syringe to apply the tensol?
  8. Cheapskate
    13 May 2007
    Syringes work well. Don't leave the stuff in the syringe too long if it has a rubber plunger. It makes the plunger swell up.
