Modding Clear plastic for clock face?
Discussion in 'Modding' started by Jim, 15 Jul 2011.
  1. Jim
    Jim Ineptimodder
    2 Sep 2007
    So, I'm not very clued about PC-modding, but I reckon you guys might be able to help.
    A relative is looking to replace an old clock face as cheaply as possible, and I'm thinking the best approach (i.e. cheaper than glass) might be modding an acrylic side-panel or similar.
    How much do you reckon it might cost to get a 30cm diameter circle sorted, 3mm thick? I haven't got any of the kit to cut it with, so unless you can buy something that spec (and I'm guessing not), I would need to pay someone to do it for me. How much work is it likely to entail?
    Would something like this do the trick, after a bit of modding?
  2. Nexxo
    Nexxo Queue Jumper
    23 Oct 2001
    Depends. If it is an old vintage or antique clock, I'd look for a replacement glass on eBay. It is a rich source of spare clock parts.
  3. Teelzebub
    27 Nov 2009
    Is it just flat glass you want ??? if so I could cut you a circle I have some 4mm thick I could cut you a 30cm circle out of that you could have that for post only
