Modding Clear protectants, does anything work?
Discussion in 'Modding' started by Cthippo, 25 Oct 2009.
  1. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I've painted a few cases, bit I've had problems with the paint easily getting scratched off moving it around or taking panels on and off. Is there a clear overcoat that works to protect the paint and can be fed through an airbrush?
  2. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    All I can think is regular clearcoat, not sure how many layers would need applying though
  3. Elton
    23 Jan 2009
    PLASTIC BAGS!!!
  4. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Depends on the paint also, I tried to clear coat certain sections of mine (i did a flat black) and it made it extremely blotchy and it was actually ruining the paint, like eating through it. I let the paint dry overnight too. If it's just regular gloss colour, a clear coat should be fine though
  5. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    There is some 2-components clearcoat around (i believe poly-urethane coating), which should be crazy strong!
