Modding Clearance/ sercurity card?
Discussion in 'Modding' started by Arkuden, 26 Sep 2004.
  1. Arkuden
    Arkuden mow?
    9 Jul 2004
    OK i know someone on this site made a guide to making a keycard for their computer to turn it on or possibly some other things. What i want to know is if there is anyway to do the same thing only with maybe a usb jump drive. Ive got a nice little 32mb one here that i dont use for anything and the idea came to me early this morning when i had to use my big jump drive. I dont need it to start up the computer so much as maybe be my login? instead of relying on a password. I did a little google on it and didnt come up with much.. any ideas?
  2. Arkuden
    Arkuden mow?
    9 Jul 2004
  3. Anakha
    Anakha Minimodder
    6 Sep 2002
    I believe in Windows 2k/XP, you can tell Windows to use a USB drive as a "Smart Card", so that'd give you login access. Never done it, though, so I couldn't tell you how,
  4. Arkuden
    Arkuden mow?
    9 Jul 2004
    ill google it, it always helps to have an extra idea to search under.
  5. Arkuden
    Arkuden mow?
    9 Jul 2004
    looks as though one has been made by a bigger company already.. not sure how much it costs though
    linky
  6. MrBadidea
    MrBadidea What's a Dremel?
    10 Nov 2001
    I'm not sure if you'd be interested, but Abit have been bundling a product called "SecureIDE" with some of their newer motherboards.
    I've looked into these things before, and all they essentially are, is a cheap PCB that you stick in-between your HDD and the IDE cable. You get a short cable with it, that you have to plug a "key" into when your booting up your machine, otherwise the HDD will remain encrypted.
  7. apollyon
    apollyon What's a Dremel?
    20 Apr 2004
    this wouldn't let you use your existing key, but it's a product along the lines of what you were looking for, except this one uses your fingerprint linky
  8. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    theres some good ones on tigerdirect
  9. calking13
    calking13 What's a Dremel?
    15 Jul 2004
    what about Zap's security circut? could only turned on with the key and locks the keyboard and mouse. i asked him about this earlier and he said try googling a loop-style security circut. I know that may not be USB but it is security.
  10. Skylined
    Skylined Minimodder
    3 May 2003
  11. Dinh
    27 Jun 2004
    theres a security USB Key like the mem sticks.
  12. livelife46290
    livelife46290 What's a Dremel?
    19 Sep 2003
  13. Skylined
    Skylined Minimodder
    3 May 2003
    Excuse me livelife46290, but that's the link that is 2 messages above yours. ;)
    I'm the one that did that circuit and guide, and yes, it's a lot of work, but taking in consideration all the mods I've seen here, doing that thing is really easy. :)
  14. livelife46290
    19 Sep 2003
    yeah im sorry, i just realized that skylined, very informative guide by the way, i never could get it to quite work but hey no worries.
  15. Skylined
    Skylined Minimodder
    3 May 2003
    Post in Electronics section, sign up at GideonTech.com MSN or just PM me. ;)
  16. Arkuden
    Arkuden mow?
    9 Jul 2004
    thanks for the info guys, it does look like it could be quite an undertaking.... ill let ya know how it turns out :)
  17. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    "calking13" all Zap did was make a break in one of wires had it go through the keylock so that when he turned it off it cut one of needed fucntions. simple let effective, you could do it with a switch if you wanted
