Motors Clio immobiliser Problem
Discussion in 'General' started by gorvett, 2 May 2009.
  1. gorvett
    gorvett What's a Dremel?
    2 May 2009
    Hello, I have got a Renault Clio RN W plate (2000).
    When I start my car sometime it will work and sometime it wont start, I've try unlocking and locking my car with the key but but it only sometime the immobliser go off and stops flashing.
    Can someone help me please.
    Lucas x
  2. Matticus
    Matticus ...
    23 Feb 2008
    Maybe your key is not disabling the immobiliser for some reason. Try replacing the batteries in the key, have you got the key wet recently?
    Also have you had any other electrical problems, like the lights seeming dim when you use something else electrical, mainly when the car is stationary. If so then your battery may not be working properly.
    You could try cleaning the battery contacts. http://www.doityourself.com/stry/cleancarbattery That seems a reasonable guide. A friend of mine has an older clio than yours and that had a dodgy battery.
    Edit: If you do clean the battery contacts, make sure you know your stereo code before you disconnect the battery, that is if you still have the original stereo.
  3. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    I'm assuming a w reg clio uses a transpoder chip in the key for the immobiliser in which case it's probably the pick up ring around the ignition barrel thats causing the problem. You could try getting a replacement from a scrap yard or ebay etc and swapping the pick up ring over and see if that fixes the problem.
  4. gorvett
    2 May 2009
    Aw thanks :) I'll give it a try both of the posts and see what becomes of it thanks.
    If anyone got anymore info on fixing it please post i would be ever so greatful.
    Lucas x
  5. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    My sister has a clio on an 04 plate, it did exactly the same thing, she had to use her second key with remote and the problem went away, it appears to be a common problem with Clio's.
  6. Unicorn
    25 Jul 2006
    As I understand it they do use a transponder chip and a pickup ring. Unless it's your keys battery or the key has gotten wet/ damaged recently it is probably the piclup ring. Another thing that can affect immobiliser transponders is strong magnetic fields. It's not likely but occasionally if your keys sit in very close proximity to something that emits a strong electro magnetic field it can scramble the key and cause the sort of problems you're experiencing.
    Bottom line you either need a new ignition barrel ass'y or a new key. Hope you get it sorted!
  7. identikit
    identikit Minimodder
    5 Jun 2004
    I had massive deja vu with this.
    http://forums.bit-tech.net/showthread.php?t=165697
    http://forums.bit-tech.net/showthread.php?t=162948
    With other threads asking about modifying Clios it looks like bit-tech ranks very well in Google with Clios and their problems!
  8. CyCoLeS
    CyCoLeS If it ain't broke...give it to me
    23 Apr 2009
    had the same issue with a Laguna. :wallbash: two keys - only one working all the time the other intermitting. had to get both keys re- synchronized with the car....dealer job and cost me about £100:miffed:
  9. Unicorn
    25 Jul 2006
    If its any consolation I have a 2007 Clio Dynamique and it has the best remote key of any car I've ever had, best range EVER and 100% reliable :thumb:
