Open Source Clone HDD
Discussion in 'Software' started by TobletDanillio, 19 Jan 2012.
  1. TobletDanillio
    TobletDanillio Minimodder
    7 Jan 2012
    I want to clone my HDD for back-up
    Where I work we use "Ghost" to image up our PCs but I don't want to buy it and I want something that is free to clone drives.
    I know that there is "Clonezilla" and this can be used to clone to network drive, dvd and usb drives but is there a better option?
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Clonezilla does a good job providing the destination drive is the same size or larger than the original.
    Any specific features that you need?
  3. Fraze
    Fraze Minimodder
    16 Feb 2002
    Bear in mind that if you are using win7, you'll probably have to run the repair from the win7 cd to use the clone drive if anything goes wrong.
    I clone my drives using a bootable Ghost CD and the installer has to re-write the boot volumes when you try to use the image on the backup drive.
  4. TobletDanillio
    7 Jan 2012
    I have a 1Tb atm but this is just a back up if my drive fails or whatever.
    Also I'm planing to getting a SSD some time this year hoping this can be copied over
    I have win 7.
    I use Ghost v8 from a USB every day at work never had to use a repair tool with win XP, XPE and 7 so I'm not to sure what yours trying to get at sorry
  5. murraynt
    murraynt Modder
    6 Jun 2009
    Drive xml is good, and it's free.
  6. azrael-
    azrael- I'm special...
    18 May 2008
    I'd probably use a trial version of Acronis TrueImage, if I didn't own it. :)
  7. Fraze
    Fraze Minimodder
    16 Feb 2002
    That's ok, the newer versions of ghost probably copy the boot sectors of the drives better - i'm using an old (ancient) version of ghost which is why i probably have to rewrite the boot sectors on win7 via the repair tool - never had the same issue with XP tho.
  8. TobletDanillio
    7 Jan 2012
    do you Sysprep windows?
    in vista and 7;
    c:\windows\system32\sysprep
    run sysprep.exe
    this will make your pc "new"(as if you just installed windows) but saving all drivers and programs installed. this could save you having to use repair tool
