Motors clutch wear question
Discussion in 'General' started by DXR_13KE, 25 May 2008.
  1. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    what "damages" more your clutch and other parts?
    (knowing you will stop for less than 8 seconds)
    A: shift the gear box from 1st gear to neutral, wait 8 seconds and then to 1st gear again to make your car move.
    B: use the clutch to stop for those 8 seconds and not shift gears (considering you are in 1st gear).
    i know its a newby question, but several people say one and other people say the other.
  2. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    B will cause more clutch wear, but is safer as you only need to lift the clutch up to regain control of the vehicle.
  3. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    do you mean use the clutch to stop as in hold the car on the clutch on like a hill or something, or just depress the clutch pedal while you are stopped with your brakes on?.. either way B will have more wear, but its certainly the easier option.
  4. DXR_13KE
    14 Sep 2005
    I am considering the scenario were you press to clutch pedal during 8 seconds instead of shifting to neutral and back (using the clutch in the process) on a leveled road and waiting for the traffic light to change from red to green
  5. HapeMask
    HapeMask What's a Dremel?
    19 Jan 2006
    From what I know about cars (little) it won't cause wear on the clutch itself but on a bearing that is part of the clutch.
  6. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    you have me confused here,
    so its a level road, at a red light. and you are going to be stopped. time isn't a *huge* consideration here, 8 seconds or 9, stopped is stopped.
    If I am at a light, and I am stopped, the pedel will be all the way to the floor, and the car is in first.
    if you want you can have the pedel to the floor, and the car in neutral.
    Either way is fine, there will be no difference in wear and tear on the clutch.
    If you want to sit at a light, with the car in neutral, and the clutch out, thats fine too.
    did that answer your question or are we talking about two different things here?
  7. fev
    fev Industry Fallout
    13 Aug 2003
    option b is what i use, having a diesel to navigate Oxford is useful, lift big toe.. crawl forward poke big toe down 4mm and stop
  8. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    There is a difference her but its tiny.
    The clutch only wears when its between fully engaged and fully disengaged so reducing the number of times you press or unpress the pedal will reduce wear.
    To wait in neutral you follow this sequence
    driving-clutch engaged
    stopped- clutch disengaged
    gear to neutral- clutch engaged
    gear to first- clutch disengaged
    pulling away- clutch engaged
    Thats four periods of wear
    For the other scenario
    Driving- clutch engaged
    Two wear periods
    Having said that the wear involved with spinning up the first part of the transmission is tiny compared to the wear involved with accelerating from a standstill.
    Moriquendi
  9. Freedom
    Freedom Minimodder
    27 Oct 2004
    If its uphill and I know that with a 6 or 7 secounds I would be move I'll properly rest on the clutch but this not good for the clutch but easier for me. All other times it's drop the clutch, on with the brake, stop into first hold the clutch down hold and brake on. when the light changes pull away in the usually manor. I do sometimes coast to stop which is a bad habit.
    If you've got the clutch pedal to the floor there's no need to put it in neutral it wont wear the clutch when the pedals to the floor
  10. dragon2309
    dragon2309 techie
    28 Jul 2006
    I'm no expert, in fact im taking driving lessons now, instructor has taught me to stay in first with the clutch to the floor, bring it up to crawl forward, shift from clutch to throttle to pull away... In my lessons, I neer enter neutral unless I'm parking or something else goes terribly wrong... lol
  11. DXR_13KE
    14 Sep 2005
    that is what i was thinking.... if you are pressing the clutch pedal then the clutch disk is not in contact with the flywheel, then it is not being "consumed".
  12. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Sorry, but all that is rubbish. Press the pedal to disengage clutch and depress it to engage. As it is a friction disc, it will gently grip the flywheel upon engaging it again. You use that slip to engage with out driving like Captain Kangaroo. If your clutch has no outer lubrication on it (oil, water, grease and the likes), meaning just the flywheel and the clutch disc connect and full contact is made. Which means no wear of the clutch takes place. The only time there is wear is between fully engaged and fully disengaged, where you use the more or less slipping friction between the flywheel and the clutch pad itself. There is also a roller bearing in the middle and that is normally what wears out, the car sounds awful with the clutch pedal down. There are there some springs that keeps the clutch engaged, that can fail from age and heat. Age being the predominant factor. If you drive sensibly that is. IF however you want to do 1/4 dragrace stuff, with a beefed up engine, get another clutch. Standard does not cut it. The engine will overcome the spring force on the pad, and you burn your clutch instead of your tires.
  13. knuck
    knuck Hate your face
    25 Jan 2002
  14. DXR_13KE
    14 Sep 2005
    So basically the act of moving the clutch 4 times to shift to neutral and back will consume marginally more clutch material than pressing down on the clutch, making it not contact with the flywheel, while producing the same effect... this is of course on a flat and leveled road and considering you will move your car in less than 8 seconds.
    right?
  15. Moriquendi
    3 Nov 2005
    Yes but were talking about a tiny difference here.
    BTW, Spaceraver, press and depress mean the same thing... isnt english great?
    Moriquendi
  16. thestig198
    thestig198 Artificially Intelligent
    24 Jan 2004
    Maybe, but pressing/releasing the clutch when the car is not in gear will cause hardly any wear because it will not be slipping for long (like it would be if you were doing a hill start). I would say you could discount that 'wear' when the car is not in gear as it will be so small compared to pulling away.
    If you leave the clutch pedal pressed down (when in or out of gear) then I think it will wear the release bearing. When stopped at traffic lights I always take the car out of gear, put the handbrake on and take my foot off the clutch. My dad has been driving for many years, he does the same and has never had to replace a clutch... ;)
  17. chrisb2e9
    18 Jun 2007
    why do you use the handbrake? as opposed to the normal brake?
  18. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Because that's what you do when you don't drive an automatic...?
  19. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    :D
  20. chrisb2e9
    18 Jun 2007
    um, no. When I am stopped at an intersection I dont have my handbrake on. level road or pointing up a hill. There is no need for it, the regular brake works just fine.
    So why would you use the hand brake?
