Cases CM 690 Grommets
Discussion in 'Hardware' started by CrapBag, 30 May 2013.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I have an original 690 and would like to fit grommets to the cable routing holes but according to the CM store the ones they sell only fit the 690 II, The holes in the 690 II look identical to the original 690 so I don't get why they wouldn't fit.
    Has anyone ordered and fitted these grommets in an original 690 or know why they wouldn't fit?
    CM 690 II Grommets
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Anyone?
  3. phoenixck
    phoenixck What's a Dremel?
    7 Jan 2012
    No idea but I've a cm 690 ii and could loan you them if you want?
  4. miller
    miller What's a Dremel?
    10 Jun 2013
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    It's that bit that bothers me.
    Just wondering if someone knew why they wouldn't fit the older version.
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    If you could lend me one so I could see if it fitted that would be great.
  7. phoenixck
    7 Jan 2012
    Send me a pm and I'll send them by saturday.
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Thanks for the offer mate but after checking the postage it looks like it is going to cost me nearly £20 for 4 grommets once the shipping is added from the cooler master eu store. (approx. £10). Why they have to be sent via ups I'll never know.
    Standard post would do.
    So unless someone has a scrap 690 II I don't think I will be getting any grommets.
  9. Pieface
    Pieface Modder
    8 Mar 2009
    Ah I just threw away my old CM690. Would have sent them to you if I didn't
  10. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Nooooooooooooooooooooooooooooooooooooooooooooooooooo :(
  11. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Last time I needed small bits from CM I emailed support@coolermaster.nl, and explained abut postage. They did pigeon post on the understanding that it was not insured and my tough luck if it didn't show up.
    The second time I ordered a few bits in one parcel for me and friends and then split the postage between us. I bought a windowed panel for my Cosmos pure so my mate ordered a normal one and another mate needed small bits so we all stocked up. Maybe styart a thread and see if anyone else needs anything.
  12. Elton
    23 Jan 2009
    Anyone know if I can find a black ATCS840 side panel anymore? That would be amazing.
  13. XSpacedX
    XSpacedX What's a Dremel?
    17 Jul 2011
    VERDICT????
    Hey Guys wanting to know this as well cause DAM white edition didn't come with them :-/
    so could someone please tell me what the out come was??
    Thanks Sam
  14. XSpacedX
    17 Jul 2011
    Hey Guys does anyone know what the out come of the was??
    As i really want them on my CM 690 II Adv White Edition any one find out if they fit or not.....
    Thanks
  15. CM Nick
    CM Nick Cooler Master Representative
    1 Nov 2013
    Hey, what are you looking for in particular?
    Maybe I can help?
  16. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I was looking for the cable routing grommets for the 690II (not the advanced) but on the cm store it says the ones you sell are for the advanced only but I don't see what's the difference between the two, hole wise.
    Also by the time postage is added they become really expensive.
  17. CM Nick
    1 Nov 2013
    Hi CrapBag,
    Tomorrow morning I will check with the RMA department and store manager what would be the difference and if we still have them. I will reply to you first thing in the morning when I know more.
    Sent from my HTC One using Tapatalk
  18. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    what the hell? do you get alerts somehow when cooler master is mentioned in forums or something?
    While your here nick, is there any SSD mounts for my case that fit in the HDD draws? Cosmos 1000
  19. CM Nick
    1 Nov 2013
    Hi Otis1337,
    No I wish it was that easy;) I came across this thread because it had Cooler Master in it.
    I will look that up together with the question of CrapBag first thing in the morning!
  20. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Thanks for looking into this for me Nick.
    I love the 690II and have 2 of them plus a scout and a haf 922.
    I want another 690II for my wifes pc so I'm keeping an eye out in the market place :)
