Case Mod - In Progress CM Cosmos II MODERN by Dave2010 [FINAL PICS!!]
Discussion in 'Project Logs' started by Dave2010_TA, 10 May 2013.
  1. Dave2010_TA
    Dave2010_TA Minimodder
    25 Feb 2012
    Thank you!!! :rock::rock:
  2. Dave2010_TA
    25 Feb 2012
    Here I am.
    In this little up, I'll show you the mounting of the SSD's inox support.
    I realize a little cover for the front panel, where there are the screws that fix the Aquaero and the other two controllers.
  3. Dave2010_TA
    25 Feb 2012
    Now an interesting step to you.
    The reservoirs aren't finish, because I don't have the oring for the upper and the lower part of them and the rest of the inox parts of them.
    But, I can make a mistake, I have not yet seen around rectangular water tank, and I like them very much.
  4. Dave2010_TA
    25 Feb 2012
    Qui ho praticato un altro foro con vite e dado M4 per migliorare la tenuta del pannello posteriore, dato che ospitando l'alimentatore sospeso rispetto al fondo del case, il peso di quest'ultimo è notevole.
  5. Dave2010_TA
    25 Feb 2012
    The small panels of glass and aluminum profiles are fixed between them with transparent silicone, also placed inside in order to improve the seal.
    Once dried the silicone, I started to assemble the various panels of the structure in steel.
    Here I practiced another hole with screw and nut M4 to improve the tightness of the rear panel, since hosting the feeder suspended with respect to the bottom of the case, the weight of the latter is considerable.
    Here is the SSD mounted properly.
    After returning from vacation will complete all the reassembly of the panels. Will complete the trays so that they can fix and consequently also fix the support for the pumps Laing. From that point on, I will go to the study of the routes of pipes for the LCS and start an email to ... a famous manufacturer of fittings.
    See you soon!
  6. Dave2010_TA
    25 Feb 2012
    Well even in this MOD could not miss. We welcome another sponsor! Corsair Italy has provided me with these fans SP120 High Performance PWM Edition.
    I thank Corsair Italy for the speed of response and shipment! And now, pictures!
    Small note.
    Note the base beneath the entire perimeter of the radiator in order to avoid that, by setting the fans, the screws may damage the raceways of the radiator itself.
  7. Dave2010_TA
    25 Feb 2012
    And now...SLEEVE!!!!
    I buy Titanium Grey MKII e Grand Bleu for "normal" cable, and Grand Bleu for sata cable: all from MDPCx. Awesome.
  8. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Progressing very nicely... Keep up the great work!
  9. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Its just getting better and better !
  10. Dave2010_TA
    25 Feb 2012
    Thank you guys!!! :D
  11. ziza
    ziza What's a Dremel?
    21 Dec 2010
    I love your backplate and the sleeve color.
    I am definitely following this one.
    regards,
    ziza
  12. Dave2010_TA
    25 Feb 2012
    Wowwww thank you!!!
  13. Dave2010_TA
    25 Feb 2012
    I'm back!
    I promptly mounted the fans are coming from Corsair as a sponsor for the mod on both radiators.
    In a few days they come from three other PcHunter. Once the replacement of two radiators, I needed to place the trays and then the pumps in order to design a sketch LCS.
  14. Dave2010_TA
    25 Feb 2012
    Construction water tank.
    My father has recovered rubber perfect for my reservoir, cut easily with a utility knife or scissors.
    Proceeds of the rectangular seals with the help of the cutter. The size is 60x55 mm, thickness 2 mm.
    Proceed with the widen the holes at the ends, going from M3 to M4, since the chopsticks that you'll see later I was able to retrieve only the M4, but I would say that is the most appropriate measure for my purpose.
    Here are the rods that act as braces to hold together the whole pan.
    Here I have devised a little trick to have the certainty and comfort to cut all 4 sticks perfectly.
    Cut made!
  15. Dave2010_TA
    25 Feb 2012
    Here with the chain M4 thread chopsticks to be screwed a nut always M4.
    Final assembly with silicone seals directly on the glass. The seal rests on the piece of steel without being glued, however, so that if in the future I will need to open the pan for cleaning or any other type of intervention, it is feasible.
    See you soon with the twin gray!
  16. Dave2010_TA
    25 Feb 2012
    Here the second!!! :D
  17. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    Came for the res posted on E22, stayed for the insane build!
  18. bundymania
    bundymania Bastelorakel Industries Worldwide
    4 Jun 2009
    Very nice ! :)
  19. Dave2010_TA
    25 Feb 2012
    Ohhhhhhhhhhhh thankkkk you Bundy!!! :D
  20. Dave2010_TA
    25 Feb 2012
    Here them mounted!!
