Case Mod - In Progress CM Cosmos II MODERN by Dave2010 [FINAL PICS!!]
Discussion in 'Project Logs' started by Dave2010_TA, 10 May 2013.
  1. imersa
    imersa Parvum Princess
    9 Apr 2009
    Really love the res' mate. Would use one of them in a build for sure!
  2. Dave2010_TA
    Dave2010_TA Minimodder
    25 Feb 2012
    Thank youuuuuuuuu :D
  3. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    This is looking insane! keep me posted on E22 ;)
  4. skyrip
    skyrip What's a Dremel?
    22 Jun 2013
    i have question and a note :p
    why use a rubber gasket when you already use silicone kit?
    about the square tubelike res not being made is becuase: a square wil get very bad forces on the middle of the plates when there is a little bit of presure wich means it wil have a higher tendency to crack.
    and i woul like to say the res looks great just do some pressure testing on it before you fill it in you pc ;)
  5. Dave2010_TA
    25 Feb 2012
    Eheh thank you!
    Ehi! Hi!
    I used also silicone because I wanna be sure that the water doesn't go out from the tank.
    In the next days I'll test them! :D
  6. Dave2010_TA
    25 Feb 2012
    And....A new sponsor!!! Very very nice to have it!!!
    Between few days, I'll receive all the items that I choose.
    The tubes that I'll use, are this below, that I show at the beginning of the mod.
    See you soon!!
  7. Dave2010_TA
    25 Feb 2012
  8. Dave2010_TA
    25 Feb 2012
    I'm back!
    A small up waiting for the material from Bitspower.
    I threaded the supports for the pumps. As soon as I have in hand all the fittings will fasten to the bulkhead and I will link below the reservoir to compose the two loops.
    Next, I mounted two other fans Corsair SP120, such as those already received sponsor directly from Corsair, which I proceeded to stare at the back and in the area on the front, which I had prepared in the design phase of the panels in stainless steel.
    I moved a few inches the reservoir blue, slightly to the right, so I would say that is much better.
  9. imersa
    9 Apr 2009
    Brilliant mini update. Following on!
  10. Dave2010_TA
    25 Feb 2012
    Thank you :D
  11. sprintdmc
    sprintdmc What's a Dremel?
    16 Apr 2013
    Hi David I loved what you did with the 600t and I think I am going to like this one even more. Great work.
  12. Dave2010_TA
    25 Feb 2012
    Ohhhhh thank you very much! Stay tuned!!!
  13. Dave2010_TA
    25 Feb 2012
    The package from Taiwan is arriving...stay tuned!
  14. Dave2010_TA
    25 Feb 2012
    Here the material finally arrived! Over the weekend we'll set to work!
  15. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Omnomnomnom nice package of Bitspower fittings.
  16. Dave2010_TA
    25 Feb 2012
    Thank you Hukkel!
  17. Dave2010_TA
    25 Feb 2012
    Here the EK top for the two Laing!
    Completed in the first loop, I still miss to position the Aquacomputer flow meter and filter.
    For the second loop you have to wait for the vga and its WB to complete the various links.
    Here are the top EK mounted.
    Both trays were spaced slightly from the bulkhead in which they are fixed, for convenience with the connection to the pump.
    I tapped M5 Both trays and spaced with the plexi.
    Bye!
  18. Dave2010_TA
    25 Feb 2012
    And this is what happen when this persons...
    ...make a good job for me!
    Thank you very much for this sponsorship!!
  19. hero1
    hero1 Minimodder
    18 Oct 2013
    This is one awesome mod and keep up the amazing work!
  20. Dave2010_TA
    25 Feb 2012
    Thank you mate!!! :D
