Case Mod - In Progress CM HAF 935 Crysis mod Final pictures and video.
Discussion in 'Project Logs' started by jones-965, 14 Sep 2014.
  1. jones-965
    jones-965 Modding & tuning
    13 Jul 2011
    Thank you for the recognition.
    The gpu cooling radiator painted.
  2. stonedsurd
    11 Mar 2009
    "MAXIMUM ARMOUR" indeed!
    Great work. :thumb:
  3. jones-965
    13 Jul 2011
    Thanks!
    The side panel is armored.
  4. CBud
    CBud What's a Dremel?
    8 Feb 2014
    this looks amazing
  5. rrtype
    rrtype What's a Dremel?
    5 Aug 2014
    amazing!
  6. jones-965
    13 Jul 2011
    Thank you for your kind opinion. [​IMG]
    Arriving at the avexir ram. Thanks for the CaseKing.de.
  7. jones-965
    13 Jul 2011
  8. jebk
    jebk What's a Dremel?
    18 Oct 2014
    This looks awesome, particularly like the doors, do the gas shocks latch it shut somehow or have you additional catches?
  9. jones-965
    13 Jul 2011
    Yes, the gas telescope lock.
  10. jones-965
    13 Jul 2011
    The Crynet-system activated.
  11. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    That's wild, I love it! :thumb:
  12. storm-83
    storm-83 Minimodder
    7 Nov 2014
    there are all kinds of awesome packed into this build - awesome execution!!!
    while i would not necessarily like sitting next to all those lights, it does add a very cool effect to the overall theme.
    the way you incorporated the cloaking effect is very cool :)
    good one, sir!
  13. jones-965
    13 Jul 2011
    Thank you very much! [​IMG]
    The design of the outer casing.
    The material is 10 mm foamed PVC sheet
  14. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    Holy f###!!(sorry but that looks awsome) :)
  15. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I really like the pipe-layout from tube-res to pump and to GPUs and back. Awesome.
  16. jones-965
    13 Jul 2011
    Big thanks!
    Today next work.
    The mask. :D
  17. Zsolt Guriga
    Zsolt Guriga What's a Dremel?
    20 May 2012
    OOOhhh,man this mask is just awesome:jawdrop:,also the idea is:thumb:
  18. jones-965
    13 Jul 2011
    Thanks Bro! :)
    The mask & armor continued.
  19. jones-965
    13 Jul 2011
    Today morning, the prepared mask taped red Plexiglas and lighting built into the upper area. This page will illuminate when doors are opened.
    The head shape modeling elements of expanded aluminum plate was covered with black and paint.
    Because the front panel control buttons, covering all been bypassed, to necessary switch on the bottom button on the front panel hid
    gluing together two pieces of 10mm PVC foam sheet, sketched out the appropriate forms and the multi-head to grinding machine beautifully adapted form.
  20. jones-965
    13 Jul 2011
    Coming Soon.
