CM Stacker cable routing
Discussion in 'Hardware' started by Brett89, 12 May 2007.
  1. Brett89
    Brett89 Active Member
    15 Dec 2005
    I'm making a new computer, with an OCZ GameXstream 600W, an an Asus A5PN-E SLi mobo, my question is, with the case, a CM Stacker, will I be able to route the 4 pin 12v cable under the mobo to the top of the case? If you have either of these, please give me some feedback on clearance and cable lengths. These may be dumb questions, I know, but I just want to make sure of things.
  2. NoMercy
    NoMercy New Member
    23 Nov 2004
    I so want to write some ultra electronics based answer to this because it seems just odd that something about where to shove cables in a case mod landed here.
    Shame I can't think of a electronics based answer to the question, thought about bus bars running around the case with spade connectors... but that's a little weird and a little dangerous :)
  3. KayinBlack
    KayinBlack Currently Rebuilding
    2 Jul 2004
    Bus bars rock. Ultra had a case with them...
    But you'd just have to measure and try it...
