Hardware CM Storm Sirus-C Gaming Headset Review
Discussion in 'Article Discussion' started by Dogbert666, 17 Jun 2014.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    USB only is a big no no for me.
  3. Pricester
    Pricester What's a Dremel?
    25 Aug 2002
    I'm confused... if you've got a 3.5mm jack, what difference does it make if you connect that to a PC or a PS3?
    Surely, whatever the source device is, if you connect the 3.5mm jack to it, and select "Console", it should work? I'd be rather impressed if a set of headphones could tell the difference between PC audio out, PS3 audio out or any other audio source...
Tags: Add Tags
