Scratch Build – In Progress CM SupreDesk
Discussion in 'Project Logs' started by TheL4mka, 6 Oct 2013.
  1. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Thank you! :)
  2. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    AquaTuning UPDATE
    Hi, today only small update about next sponsored package from Aquatuning.de.
    In this package is second D5pump, tubing and few fittings and nice present - AquaTuning T-shirt!! :)
    Thanks a lot for this help!
    D5+TOP, tubing and fittings all Alphacool.
    Very nice T-shirt! I really like it :D
    Stay tuned, on weekend will be bigger update with GPU :)
  3. Boorach
    Boorach Minimodder
    16 Feb 2013
    Lovely build. Really like the clean lines and 'outward' simplicity of the desk itelf. Great job so far and look forward to following your progress.
  4. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE
    Hi, at the weekend I installed block on GPU and fit it to the mobo and connect some more tubing :) Tomorrow I will install the second pump into desk and will do some flow tests.
    Asus GTX770DC2OC and EKWB block
    Naked 770
    And with EKWB block :)
    Installed GPU in MB and connected with tube to RAM block
    More tubes connected.
    From GPU will be connected into ST30 360mm radiator.
  5. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    looking good :D
  6. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Thank you :)
  7. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE
    Hi, this update is one of the last, because desk is almost finished :)
    I fitted Mainboard into desk and connect all tubes.
    MB with slot in desk - without cables.
    Detail of ASUS GTX770DC2OC - again thanks ASUS!
    View of HDD standings.
    And another one :)
    Connected sleeved extension cables into MB and GPU.
    MB in place with extensions connected to PSU cables.
    Overall view of desk.
    View of 'left side' of desk with MB.
    Detail on MB with connected cables and tubing
    Reserviors - Alphacool :)
    And view of PSU CoolerMaster V850 - thanks a lot for this super PSU!
  8. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE
    Hi, here is the last update. Desk is finished and in next few days I will upload final photos.
    Installed second D5 Alphacool pump from Aquatuning.de
    And started to fill the loop :)
    One very little leak. Fittings were not tightened well, but i fixed it and now it is okay :)
  9. hero1
    hero1 Minimodder
    18 Oct 2013
    Nice work mate. Are you planning on doing a tidier job to the cables that are powering the pumps and such?
  10. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    FINISHED
    Hi, so.. Desk is completely finished! :)
    I would like again thanks to my sponsors:
    CoolerMaster
    ASUS
    EKWB
    AquaTuning
    Very big thanks to them for supporting me with amazing products to my project! :) :rock:
    FINAL PICS
    Everything about this - photos, buildlogs, hardware etc. used in build you can find on:
    www.cmdesk.eu
    Wish you all Merry Christmas and Happy New Year! :)
