CM Wavemaster - [Mostly done]
Discussion in 'Project Logs' started by ouija, 8 Feb 2005.
  1. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    This project is for a friend's Wavemaster case that I really should hurry up and mod since it's been sitting for months. :blush:
    Most of the PSU modifications are done, but I'll post pics of it later when it's completed. As far as the window goes, it's basically the same as my PC-70's window. It's been cut and needs filed, but first it needs to be a little larger so more pics of that later.
    First, here's pictures of some of the "stuff". The LCD isn't shown since the one that arrived had the wrong colour backlight.
    5.25" Bezel for the LCD - front plate will be replaced with proper CoolerMaster
    Some 80mm white CoolerMaster LED fans
    The same fans as my slimline fileserver. Here's one powered on
    Two 12" white cathodes
    Cathodes powered
    Globalwin 520w PSU
    Layout of the window
    Handy for corners
    Still roughly cut - needs filed/sanded
    Another view of the window
    That's all for now. No explaining the plans, only progress as it happens :D
  2. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    looking good so far, so that drill attachment for the dremel whats it for? like etching type of stuff? like could i cut a complicated design with one, on a steel side panel? I wanna do a dragon but its pretty complicated, is it like a pencil?
    how do you know which cuts metal?
  3. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    That is gonna look great. The white on aluminum inside always looks amazing. Nice simple but clean window. Badass case to start with. :rock: :rock: :rock:
  4. ouija
    10 Nov 2002
    It's for cutting. It can be used to cut pretty complex designs but I used it for the curved corners. I still think a smaller bit would have left a much cleaner edge with less need for filing.
  5. GigantoR
    21 Jul 2004
    The CM fans are great. I am using some of the UV green 120s and they are SILENT.
  6. MNC Fear
    MNC Fear Banned
    7 Feb 2005
    Nice Kit- id like to see the window when its finished though- Not too sure about the shape
  7. Derelict
    Derelict What's a Dremel?
    29 Jan 2005
    I absolutely LOVE that PSU...sexy.
  8. ouija
    10 Nov 2002
    It's the same shape as this project. There are better pics of that shape in that log, but I will post more once I increase the window size.
  9. Wrigley1
    Wrigley1 What's a Dremel?
    5 Dec 2004
    Whooo another ouija project! Nice work so far!
    I'm assuming the LCD will be white? Can they do that these days? Or is it blue, like the PSU?
    Also, what's with that drive bay cover? There is some sort of film around the hole, the entire thing has another layer of clear film on it, and the right tab thing looks like it is bent in to the inside at about 130 degrees. Is it made of cardboard, or are you metahuman enough to bend it in? :eyebrow:
  10. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    hehe i thought it was a stacker not a wave master :) hehehe
    so would all the bits cut metal or what? can it cut through steel?
  11. ouija
    10 Nov 2002
    Derelict: The PSU will look even better when it's finished. :)
    Wrigley1: No comment on the LCD or PSU :) The LCD bezel has a protective sheet on it and the bulge at the back is the pack of screws that comes with it. The leg isn't bent, it's just the perspective of the shot. :thumb:
    Bboy_Jon: Yes, the bit will cut steel. You use the 90° attachment on the dremel and drill in like with a normal bit. Then you can proceed to cut in any direction keeping the bit perpendicular to the surface. Pretty handy cutting bits.
  12. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    ouija I've tried to use the same Dremel accessory and bit to cut a slot into a perspex sheet, but the result was not so good (melting and rough edges). Can you give me some suggestions about that tool?
  13. ouija
    10 Nov 2002
    Hmm... it's a shame they don't do smaller or finer bits. Are you using any lubricant when cutting? I'm going to give that a try next time I use it.
  14. papeniglio
    5 Dec 2002
    No lubricant.... and I think they don't make finer bits just to avoid some noob-like-me break the bit at the first cut!!!
  15. ouija
    10 Nov 2002
    I would try a slower speed and cut gradually. Plexi will usually melt when drilling/cutting and dry on the bit which makes it even harder to cut with. Maybe try using water or something to keep it from melting?
  16. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    where's your next update?
    i dont see it
    nice work btw
  17. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    You dont have troubles, of having not enough fans :D :D ....
    But Nice Dremelling!
  18. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looking good :)
  19. luis_pedro_Sato
    luis_pedro_Sato Minimodder
    29 Nov 2004
    yes.
    wating for the rest!! :rock:
  20. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    so ALL of those bits will cut metal? theres not some that are just for wood or something?
    the psu is awsome
