CM Wavemaster - [Mostly done]
Discussion in 'Project Logs' started by ouija, 8 Feb 2005.
  1. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    ~subscribed
    Do I have to say more ?
  2. phoeneous
    phoeneous What's a Dremel?
    16 Aug 2004
    If that bit he is using is #561 then yes it cuts alunminum. Here is a small description of it.
    http://www.dremel.com/html/home_fr.html
  3. Protius-X
    Protius-X What's a Dremel?
    31 May 2004
    That attachment you have for your dremel, is that the router type attachment? And did you cut your whole window with it? Does it cut steel?
  4. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
  5. ouija
    10 Nov 2002
    The PSU is complete! :thumb:
    Basically, I planned to replace the fans. When I did, the LEDs weren't geting enough power. The fan speed was variable. I've isolated the fan LEDs and wired them straight into the 12v rail of the PSU. I originally used the fan only connector on the PCB, but this only provided 5v along the 12v rail. I'm beginning to think I had it plugged into the spare fan connector instead, but now the LEDs are connected straight to the bottom of the power supply's main PCB. Here are some pics:
    Oops :blush:
    Blue LED fans and ugly gold grills removed
    Blue tinted plexi removed
    New clear plexi (still with protective cover)
    Fan only connectors removed. I used these to wire up the LEDs for the fans
    Testing the fan LEDs on the chosen resistor
    Stealing 12v from the PCB
    The whole lot wired up
    Before modifications:
    PSU as it was before any modifications
    In the dark
    After modifications:
    Grills replaced with chrome wire grills. Ugly 230v sticker also removed.
    Some night shots
  6. Bandit_zoraK
    Bandit_zoraK What's a Dremel?
    29 Nov 2004
    I dunno something about white leds is just so silky smooth and elegant looking. Much better than before I think
  7. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    White LEDs do look very good. Nice work.
  8. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Hmm nice :D Any plans on sleeving it's wires?
  9. TMM
    TMM Modder
    12 Jan 2004
    Awesome! White is the new blue tbh :p
  10. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    PSU definately looks better than before, the white really brings out a misty glow :)
    <A88>
  11. ouija
    10 Nov 2002
    You will find out soon :)
  12. Jipa
    5 Feb 2004
    Why didn't you remove all stickers? That warranty and Active PFC? I think those aren't much prettyer than the 230V-sticker ;)
  13. ouija
    10 Nov 2002
    You can't see them when the PSU is installed ;)
  14. Jipa
    5 Feb 2004
    that sounds logical, but IMO you anyway should remove them ]:> 'Cause if you leave them there, someone'll anyway see them :eyebrow:
  15. Tech-iT
    Tech-iT What's a Dremel?
    12 Aug 2004
    The white LED's look sexy in the dark. How do they look in the light?
  16. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    Love the way this is turning out man. I am either going all whit or all black in my next project. This is making me lean towards white, although my current project is white with UV green.
  17. vapb400
    vapb400 What's a Dremel?
    24 Feb 2005
    Those white LED's look awesome!
  18. Fantaz
    Fantaz What's a Dremel?
    19 Jul 2004
    Why'd you put windows in the PSU if the case door covers it? lol Sort of a waste.
  19. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    updates pls :D :D :dremel:
  20. ouija
    10 Nov 2002
    If you look at the before and after shots, you will see the PSU came standard with blue LED fans and blue tinted windows. Also, I'm not explaining what I plan to do next, so you don't really know it's pointless. It might not be :)
    A small update, I've received the PSU sleeving and the fan controller. I've begun applying the braiding and will post pictures in a day or two when it's complete.
