Cooling CM Wavemaster
Discussion in 'Hardware' started by cool_dude, 18 Feb 2005.
  1. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    hi,
    i think this would go here....
    anyway
    ive been thinking of watercooling for a loong time. Ive just got myself a coolermaster wavemaster forgetting about watercooling. Now i remembered (once i bought it) its hard to wattercool in there :jawdrop: As there is only 80mm fan placments, unlike my old antec sonata which had a 120mm rear (where i could have put my rad)
    Has anyone got any suggestions to what i can do? i dont want to cut up the case, its lovley and i will muck it up. Any xamples on watercooling with wavemasters and i would b gr8ful. Thanks :D
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Unless you mount your rad externally, it's not really possible to mount a decent sized rad without hacking up your case.
    A cut in the top panel, or a modification to the 3.5" drive bay mounts for a large rad wouldn't be too difficult to do well though would it?
  3. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Top panel or the front would most likely fit a Thermochill HE 120.1 or a BIX. I'm sure if you check out coolmiester's Wavemaster projects you'll get a few ideas from them ;)
  4. cool_dude
    26 Aug 2004
    welll im not too confident on cutting the case myself - any idea how much the top blowhole hole would cost and where i could get it done?
    thanks people :D
    Edit;
    gotta save up a bit more :sigh: :sigh:
