Modding CM690 II and Zalman Reserator 1 V2
Discussion in 'Modding' started by gcwebbyuk, 6 May 2010.
  1. gcwebbyuk
    gcwebbyuk Dib Dabbler
    16 Feb 2010
    Not totally sure if this is in the right section, but wanted to see what people thought of my current build.
    It started out as a Phenom 965C2 build in a small Coolermaster Elite case. It was air cooled and I tried to keep it as quiet as possible.
    As you can see from the first pic here, it was quite tight in the case with a Zalman CNPS10x Quiet cooler, and also the fact the cooler blocked 2 of the RAM modules:
    I then swapped to a Zalman CNPS9900 NT cooler to allow me to use the other two RAM sockets:
    I was running a Zalman GV1000 GPU cooler which was important as the Gigabyte/Zalman cooler was at 100% fan speed all the time and only had a 2pin fan connector :(
    I then started playing around with moving fans around and adding more to keep temps down:
    But then decided that the case was too small, so moved onto a CM690-II Advanced...
  2. gcwebbyuk
    16 Feb 2010
    This image shows the build with a CNPS 10x Flex fan with an S-Flex E and a Kaze Slim fan attached:
    Also my attemps at braided cables, and the 2 Scythe Quiet Drives for my mechanical drives:
    I also then modded the Zalman cooler with two Scythe 92mm GTs to try and make the GV1000 even quieter:
    However after spending a lot of time messing about with fans I bit the bullet and decided to go watercooled with the Zalman Reserator:
    This was OK, but temps were a little off perfect, so I added an XSPC RX240 radiator too:
    And as you can see from here, my final temps aren't too shabby after a 12 hour Prime95 run:
    The case now has 5 S-Flex E fans all running at 630rpm:
    2 on the XSPC as intake (in the photo they are GTs, but I changed them to S-Flexs as wasn't keen on the noise of the GTs.
    1 on the rear as exhaust
    2 on the top as exhaust
    I welcome your thoughts!
  3. gcwebbyuk
    16 Feb 2010
    Full System Spec:
    AMD Phenom 965 C2 - 140TDP Version
    Gigabyte 790XTA-UD4 F3f BIOS
    8GB Corsair XMS3 1600MHz 8/8/8/24
    1 x 80GB Intel X-25-M SSD (OS: Windows 7 64bit)
    2 x 1TB Samsung EcoGreens in Scythe QuietDrives (Data and Backup)
    Gigabyte ATI HD4870 1GB - soon to be replaced with an Asus 5770 1GB
    Asus Essence STX - Logitech X230 Speakers / Grado SR80i Headphones
    Coolermaster CM690-II Advanced case
    Corsair HX620W PSU
    Zalman Resorator Watercooling kit
    XSPC RX240 Radiator
    5x Scythe S-Flex E fans running at 630rpm
    Saitek Eclipse II keyboard & Cyborg V3 Mouse
  4. gcwebbyuk
    16 Feb 2010
    New additions arriving soon:
    Asus 5770 - arriving Wednesday
    Aquatuning goodie bundle in white!
    In due course:
    Some better speakers possibly...
  5. gcwebbyuk
    16 Feb 2010
  6. gcwebbyuk
    16 Feb 2010
    My resorator looks bent :jawdrop:
  7. gcwebbyuk
    16 Feb 2010
  8. lmth
    lmth What's a Dremel?
    29 Jun 2010
    It must be a very expensive project.
  9. gcwebbyuk
    16 Feb 2010
    It wasn't so much a project - and not really a mod - just didn't know the best place to show some pics.
    Slight change from the last pic - I now have AudioEngine A2 speakers instead of the M-Audio AV20s - went through 3 sets, they all hummed and all were off balance. The A2s are amazing!
    I have also now re-used the old case, bought a MB/CPU/RAM kit off of FantasticDan on here, and a Corsair CX400 PSU, used my CNPS10x Flex as a cooler, and the Phobya fan I won on the AquaTuning comp and made a Silent Server too :)
