cmos checksum error help...
Discussion in 'Tech Support' started by Springs, 28 Feb 2007.
  1. Springs
    Springs Boing boing
    29 Aug 2004
    at the weekend i took my computer apart and cleaned/rebuilt it.. since then everytime i have started the computer it comes up with a cmos checksum error on startup... and i dont no why.. everything except a hard drive went back in the same place.. ive noticed nothing wrong with the computer so it hasent effected the performance..
  2. Krikkit
    21 Jan 2003
    Check the battery isn't flat, that's often the culprit (could've nudged it etc).
    Have you tried plugging the other HD back in?
    You could try reflashing the BIOS, that'd probably help. Which mobo is it btw? It's not listen in your sig. :)
  3. Springs
    Springs Boing boing
    29 Aug 2004
    mobo is a gigabyte K8n-ultra 9
    the hdd is really only a storage atm... could try BIOS flash and the battery...
  4. sackingz123
    sackingz123 What's a Dremel?
    7 Feb 2007
    yea, i would check the battery out. Maybe its out.
  5. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Clear CMOS, this always happens to me when I install stuff temporarily. My BIOS is like hey you just put something in and took it out, I am confused.
    So have you tried a CMOS reset? If that doesn't work possibly a dead battery.
  6. kaleb2006
    kaleb2006 What's a Dremel?
    28 Feb 2007
    Re:cmos checksum...
    hey i also got the same problem...But get rid from it by just replacing the cmos battery. Ofcourse the cmos battery is the cheapest part of the computer. Hope this will help u. :hip:
  7. DougEdey
    5 Jul 2005
    I find that on certain boards, just going into the BIOS and saving/exiting works.
  8. Springs
    Springs Boing boing
    29 Aug 2004
    thanks ill try the BIOS and battery if not ill just get a new one..
