Case Mod - In Progress CMSTORM PROJECT: Cooler Master Scout "Miltary Digital Camo" (Updated, Computex Clip!)
Discussion in 'Project Logs' started by mnpctech, 9 May 2009.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    This Case Mod was done by bit-tech's MOTM Sponser, Mnpctech!
    Customize your PC or window with custom Stickers from Mnpctech HERE
    This will be another Insane Case Mod by Mnpctech.com
    Heres a little recap video of the project for ya'll
    Nate CustomPCMax and I have been given a new mission.
    We have only 2.5 weeks to build a military theme "Scout" Gaming Rig for CM Storm's display at the Computex Show.
    The Scout arrives at Mnpctech.com's Workshop. It's an awesome case. It's gonna be hard having to give it up once it's finished! :D
    not finished, the stainless socket screws will be replaced with black ones
    You know Ive got em, so I'm gonna use em! Black anodized machined aluminum case feet and I'm gonna use them! :D
    Photos before packing case for Computex Show next week in Tapei :thumb:
  2. stonedsurd
    11 Mar 2009
    Dear lord, ANOTHER one?!
    I'm subbing this without having ANY idea of the final outcome.
    OT: Can I work for you? Like bonded labor? :lol:
  3. Spoooon
    Spoooon New Member
    19 Mar 2009
    Really looking forward to this! :)
  4. Kenny_McCormick
    Kenny_McCormick Member
    19 Sep 2006
    Military theme... I'll try some urban or ACU camo. Combined with green (night vision) lighting, can be a great result. Straight lines and some black rubber elements. Those are a few ideas. GL & HF!
  5. SkiDave
    SkiDave Active Member
    16 Mar 2008
    Good Luck :thumb:
    I can't wait to see how this turns out.
    Subscribed!
  6. bagman
    bagman Well-Known Member
    18 Apr 2009
    good idea as the case already does look a bit industrial which will help
  7. CustomPCMAX
    CustomPCMAX Computer Geek
    2 Apr 2009
    I am very excited to be able work with Bill on this project. To have this system head to Computex is an unbelievable honor.
    It tells you a lot about Bill's reputation too... CM trusts him to get a nice mod done in a matter of a couple weeks. This should be an interesting and fast moving mod to watch!
  8. stuartwood89
    20 Aug 2008
    I'll be watching this. I love your mods Bill.
  9. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Sweet. I just read the Scout review, and looks to be a great LAN box.. durable, and chock full of LAN-centric features. :D
    Can't wait to see what you do with it Bill!
  10. jhanlon303
    7 Sep 2006
    The review was nice. Thanks.
    It's the 2.5 weeks that is the pressure..
    Bill can pull it off if anyone can.
    john
  11. subset7
    subset7 Spanking the Monkey
    31 Aug 2008
    It'll be interesting to see what you do with this,being a new case and all and the timescale,looking forward to it,sub'd :thumb:
  12. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    kicking back and setting up camp...
  13. mnpctech
    21 Apr 2003
    I will try and do a video review of the case, it will have to be tommorow before I dismantle it. If you want mobility, the scout's handle is brilliant tho. I like it
    CM STORM logo. Storm is Cooler master's high performance sub brand, like what SVT is for Ford
    Heres the concept for the front Cooler Master chose. I'm making a front grill, using 2 of the "eye of the storm" designs from the CM Storm logo. I may change things a bit, just cause I'm like that... if time allows of course
    1/8" thick "smoked" acrylic sheet
    Using 2x 120mm Radiator Template to position. You can download your own Radiator templates
    Using band saw to cut the "smoked" acrylic
  14. bagman
    18 Apr 2009
    nice ideas you have there
  15. mnpctech
    21 Apr 2003
    Thanks! The objective is keep the mods simple without causing any major surgery to the case.
  16. stonedsurd
    11 Mar 2009
    So that they don't 'whine' about how different it ends up looking? :hehe:
    Great work!
  17. mnpctech
    21 Apr 2003
    Bingo!
    Diagram of the CM Storm Scout
    1st order of business is to open the top perforated 140mm grill to help improve airflow. The top handle will have to be removed in order to perform this procedure.
    The plastic carry handle is reinforced with steel. You can remove the handle's plastic shell by removing the 4x 140mm fan screws and 2x screws towards the top rear of the case
    2x screws are located underneath the front I/O ports
    To pull the top handle's shell off with the cables, the factory cable ties must be cut
    This is as far as I'm going to pull the handle off. ....cause it will be a PITA otherwise
    Closer look at the 140mm top exhaust grill
    4x screws fasten on the steel portion of the handle. Notice it has large tabs that slide into the top of the chassis.
  18. jhanlon303
    7 Sep 2006
    That's a SERIOUS wire bundle for the front panel. :jawdrop:
    I watch.
    john
    It takes me 2.5 weeks to pick a color - you do a whole mod.
  19. stonedsurd
    11 Mar 2009
    And so it begins.
    I'll be keeping on eye on this as well ;)
  20. Guest-23315
    Guest-23315 Guest
    Crikey! How many mods on the go is it now eh Bill?
    :thumb:
