Case Mod - In Progress CMWS23 Project "n°79"
Discussion in 'Project Logs' started by ivory2k19, 18 Oct 2022.
  1. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    Hello Community
    It was quiet for a long time but there is still a project for the CMWS22 at the end of the year...
    Since this championship has been suspended for the last year, it is even more difficult to deliver this year, because everyone is really keen on the event.
    This year we will compete with a tower mod, but I'm more into scatchbuilds, so I just don't have the time this year.
    As you can see from the title, the project is called n°79, some of you might know that the number 79 stands for the precious metal gold in the periodic table.
    [​IMG] [​IMG]
    The case is a Cooler Master MasterCase SL600M a really nice and spacious case, since I am already a bit more advanced in modifying the case I can only show you the first draft this was created about a month ago when the case arrived and the planning of the entire project started it showed that this can not really work so there were changes.
    The colour concept should correspond to the theme of gold, black and grey, it should not appear too overloaded, so the case retains its colour and is "only" modified and gets accents of gold.
    The concept with the PSU at the bottom of the case and the turned tray remains, but for reasons of space the tray is moved a little to the middle of the case and the GPU moves to the other side, so it can be longer and thicker because the sheet metal wall of the case is cut out at the back so that the GPU can breathe. In addition, the glass panel can remain and does not have to be redesigned.
    Since the case only supports 360mm radiators on the upper and lower side, my idea is to place them at the front and rear, since this way it is easy to get to the connections to connect all cables in the lid and thus they are not visible and can be led out at the top of the rear, but this requires a rough intervention in the entire case structure.
    There are 2 large 200mm fans included in the scope of delivery, which go into the rear and ventilate the radiator and hardware inside.
    I don't want to reveal too much, so here are some photos of the hardware.
  2. ivory2k19
    8 Feb 2019
    As already mentioned, the Cooler Master MasterCase SL600M in the grey version
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    The whole thing is powered by a Cooler Master Masterwatt 650, although I'm not sure yet whether that will be enough and whether I won't stock up on this one, which was lying around at home and offered itself to me.
    The fans to be mounted in the front of the case are not RGB fans but still very high quality, namely the Cooler Master Masterfan SF120M.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    At this point I would also like to thank all the sponsors
    MSI, Intel, Cooler Master, S3+ and of course my Tam the Italy Extreme Modders!
    More updates will follow soon stay tuned
    The_Crapman likes this.
  3. ivory2k19
    8 Feb 2019
    douglas alves likes this.
  4. ivory2k19
    8 Feb 2019
    Hi Bit-Tech it was a bit more stressful than I thought but now I can show you a small part of the project the rest will follow I just have to upload all the photos and find them in the right order. :hehe:
