Scratch Build – In Progress "CNPC" - Cheap PC and CNC components all in one case
Discussion in 'Project Logs' started by iD2, 29 Mar 2012.
  1. iD2
    iD2 Minimodder
    25 Mar 2012
    Update PC Card Slot Cover
    A little update with PC Card Slot Cover.
  2. iD2
    iD2 Minimodder
    25 Mar 2012
    Back to my work, try to test assembly case to prove that everything fit together but still need to drill and tap top panel and right panel i think i’ll finish top and right panel soon.
    Test assembly
    Top and Right panel design
    :D
    p0Pe likes this.
  3. Phyonics
    Phyonics What's a Dremel?
    4 Oct 2011
    Looking good :thumb:
  4. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you :D
  5. exexs
    exexs What's a Dremel?
    4 Mar 2010
    Wooo.. good acrylic job! Fits perfectly :)
  6. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    So let me get this straight, you build your own CNC, and am now making a machine with the machine you build?
    Mod-ception! And i love it:D
    Keep up the good work! ;)
  7. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you :D
    :D:D
  8. iD2
    iD2 Minimodder
    25 Mar 2012
    Just finish cutting right panel and finish drill ,taps top panel and next step i’ll do spray paint.
    Right Panel Work
    Top and Right panel
    Note :: For anyone want to see images of my cnc build log (include cnpc case build) you can see it here Photo gallery
    *** Warning image over 550+ images***
  9. Baguette
    Baguette What's a Dremel?
    6 Aug 2010
    Now THAT is clean precise work...that's sizing up nicely :D
  10. Cheapskate
    13 May 2007
    Lovely work.:D
    I have to say that using 'cheap' in the title is misleading. Nothing I've seen here is cheap. Everything is top-notch.
  11. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you.
    Thank you :D For 'cheap' it's about my pc part and component most of them was second hand parts and hardware for build this case (aluminium profile and acrylic) was cheap than brought aluminium case and mod that aluminium case , actually i need to build extreme pc case with high-end part and using water cooling system too but most of my money just spend to build my cnc.
    XD
  12. Samrobmoe
    Samrobmoe What's a Dremel?
    7 Apr 2012
    I love the precision engineering in this project, something I only wish I could achieve...
    Good work!
  13. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you :D
  14. iD2
    iD2 Minimodder
    25 Mar 2012
    Finish right and top panel and some other update !!
    I'm just finish right and top panel . Not much description because i'm not good in English but this image will describe what i'm done and what i'm working.
    Right and Top panel and Other work
    :D :D :D
  15. Phyonics
    4 Oct 2011
    Looking really good!
  16. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you :D
  17. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
  18. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Yup, just creamed my pants
    thanks a lot :(
  19. Pranja
    Pranja Blackwolf
    18 Dec 2011
    GJ. Looks nice. ;)
  20. rak500
    rak500 Minimodder
    22 Aug 2009
    Can't wait to see it all build up, Awesome build!
