Scratch Build – In Progress "CNPC" - Cheap PC and CNC components all in one case
Discussion in 'Project Logs' started by iD2, 29 Mar 2012.
  1. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you :D
  2. iD2
    iD2 Minimodder
    25 Mar 2012
    Update, Assembly PC and extend 4pin PSU wire
    Just assembly PC and have some problem with 4pin wire to connect motherboard , it too short and i need to extend it about 20- 30cm. :(
    After finish extend 4pin wire , than test open PC to make sure it still work.
    Put CNC Component to case
    Left panel
  3. iD2
    iD2 Minimodder
    25 Mar 2012
    OK, Start to wiring and put some stuff to case.
  4. Attila
    Attila still thinking....
    22 Feb 2008
    Nice work mate, I read your worklog on CNC zone. Fantastic work!:thumb: I can't believe you have built that thing in your bedroom. Awesome work, awesome machine.
  5. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    There are some times, if you really want something. So it does not realy matter for him/her they just do it. And when its redy, looks absolutly sunning. Even if it is made in the bedroom.
    So what ever you are doing dont give up.
    I realy like your cnc.
  6. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you :D , Building CNC in bedroom there were a lot of problem but big problem was noise when drilling but everything was done :D . Now i concern if one day i need to move out from this condominium that mean i need to disassembly my CNC :jawdrop: it'll big job too.
    Thank you :D
    (sorry for my English , if any words was not correct please tell me)
  7. iD2
    iD2 Minimodder
    25 Mar 2012
    80% Finish Wiring
    Still working with wiring everything together
    80% Finish wiring
    My case vs Standard case
    Next job
    This my next job to use this resistor to reduce 12v to 8v , to make fan quiet. Actually i need to use PC Fan Control it can adjust voltage but it expensive so i decide to invest with this resistor it very cheap.
  8. iD2
    iD2 Minimodder
    25 Mar 2012
    Just back to work !!! Sorry for nothing update for long time , my routine work very busy . I don't have much time to work so this a little update and need to finish my case soon.
    Case Handle
    will be back soon.... :D
  9. bulldogjeff
    2 Mar 2010
    Now everything about this project is just seriously cool !
  10. Drysofar
    Drysofar What's a Dremel?
    5 Nov 2006
    If you want to run the fans slower but not at 5V you can skip the big resistors and just connect between the +5V live and the +12V line of your pc PSU this gives you 7V for the fan.
  11. Drysofar
    5 Nov 2006
    As Sulu once shouted, Shields !!!.
    You may also want to consider a solid or mesh metal cover for the PC motherboard as the CNC equipment can be very electrically noisy.
  12. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you :D
    I never know that ,i'll use volt meter to test it if it work it will be good option to avoid big resistors. Thank you.
    :D thank you for your advice ,i'll design cover plate for my motherboard by using acrylic ,it look like asus sabertooth but i'll do it after everything finish.
  13. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Your attention to detail is astonishing as is the craftsmanship!
    Top stuff, await your next update!
    Thanks.
  14. iD2
    iD2 Minimodder
    25 Mar 2012
    Hello, Long time nothing update because i need to work out of my office and my PC was dead stil waiting for RMA but can't wait anymore , so i decide to sell my pc component and bought new one.
    New Spec ::
    CPU --> AMD A6-3670K
    Motherboard --> ECS A75F-M2
    Ram --> Old Ram (2x Kingston bus 1333)
    PSU --> (This part was dead , still waiting form RMA) , New RaidMax 730Watt
    OK, Just back to work not much update but need to update my new PC and something i already done.
    Foot base
    Custom chip heatsink
  15. iD2
    iD2 Minimodder
    25 Mar 2012
    Long time nothing update on this forums , Now big update. Let's see.
    Foot base
    Led light
    Side Panel
    Put spindle inverter to case
    Side panel when connect wire component
    Font right panel
  16. dream1
    26 Feb 2011
    This looks very simpel but jet very cool :) . The wiering shold be littel better but i understand if there is any problem u wanna acsess fast but sill i lke it very much :)
  17. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you, You right my wiring was not look clean and i need to make it looking better but now i need this case finish and work well and still have no idea how to do with a lot of wire.
    :D
  18. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Awesome Job iD2! Makes my box look oh so dull now,,, :p
  19. iD2
    iD2 Minimodder
    25 Mar 2012
    Just finish my Left font side panel , not much anything to describe just see picture.
    Aluminum for hold acrylic
    Put it in Case
    Start cutting acrylic for font left panel
    Finish cutting and put it in
  20. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you :D
