Woop!! The Nazi Zombie level is probably my most favorite level out of the COD series, only downside is you can't use your own custom setups, and also I can't seem to get past level 9. *There's a glitch somewhere in the game whereby if you go prone upstairs & someone else does the same, the zombies can't get you, I suppose it would make the game kinda pointless and is probably why I haven't done it.
yes, i got to lvl 35 with it, gave up because i got bored. my friend was in it and he had over 5000 kills (3499 headshots.) all you do is sprint jump at the corner of the wall, then go into prone while in mid air. then get a friend look at the other side of the wall and if your legs are sticking through your in. the last place your feet touched the floor is where all the zombies pool. i would sugest getting a flamethrower and just tap RT so it pulses and you dont overheat. im going to download them now!
I hit max level (10) in multiplayer and only got to wave 28 in zombies. Really no point to continue on and I assume the new pack is for the 360 as of now.
New pack is for 360 and PS3 for now, PC eventually when they can work out a way to charge for it. Zombie Asylum is somewhat harder than the original...
