Mods, move this at will, i wasnt sure where to put this. sorry Im having problems with the Xvid codec with winamp. For some reason the colors are all screwy. Its like the hue is messed up. It doesnt happen in windows media player, but i dont wanna use that cause i cant do full screen with it for some odd reason. Can someone help? I heard it has something to do with directX but i havent found anything usefull that will fix the problem.
go to www.doom9.org and try one of their filters. If that does not work, just read around in their forums.
I hope you havent installed the xvid NIMO codec pack cos that causes a lot of problems. There a few differnt xvid builds so you might need all the xvid codecs. The good codecs are. XVID codec by nic XviD-04102002-1.exe XviD.Root.24.02.2003.1100 With these codecs ive ran movies fine on winamp.
