Modding coin ring
Discussion in 'Modding' started by fartonmyear, 28 Apr 2005.
  1. fartonmyear
    fartonmyear What's a Dremel?
    16 Jul 2004
  2. joecaprini
    joecaprini What's a Dremel?
    21 Aug 2004
    It's not bad for a first try, I am still getting screwed over by my dremel. I will accidentally make a tiny slip and screw everything up.
    So let me get this straight, you hammer the edges to it gets flat like that on the outside? Because i tried it and bent my quarter :sigh:
  3. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I think you should be made aware it requires a pure silver coin.
  4. fartonmyear
    16 Jul 2004
    i realized that the first time around. alas i lack pure silver to just throw away. but hey. it's pretty good for pounding on a piece of metal with pliers. yes pliers. i didn't have a hammer.
  5. foxx
    foxx What's a Dremel?
    5 Sep 2004
    No, on hackaday it says it can work with a quarter.
  6. fartonmyear
    16 Jul 2004
    i made a practive one initially with a quarter. it's too thin to work, unless you're making a girl's ring. the one pictured it a 500won (korea) coin. it's between the size of a 50cent and quarter.
  7. Mister_Tad
    27 Dec 2002
    if you hit it in the right way, you can knock the centre part out of a £2 coin which would get you half way there :)
  8. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    i saw this on hackaday too, i'm making a ring out of a winston churchill 25p (?) coin circa 1965. it's frickin huge!!!
    can anyone tell what year that JFK coin is from? i have one, but it's a copper sandwich one. i laughed out loud when i saw the pic of the coin with the hole drilled right through JFK's head, although i have a morbid sense of humor...
  9. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    can u actually like bend the coin with a spoon?
  10. foxx
    5 Sep 2004
    I dont think so, not with a quarter at least.
  11. I'm_Not_A_Monster
    22 Dec 2003
    you don't bend it, you use the spoon as a hammer. i got impatient and used a carpentry hammer, it's working great
  12. fartonmyear
    16 Jul 2004
    silver is soft i assume. a spoon is steel. steel > spoon
  13. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    :waah:
  14. offroadracer789
    offroadracer789 What's a Dremel?
    9 Dec 2004
    i made one with a quarter, and now im making one with a gold dollar.
  15. I'm_Not_A_Monster
    22 Dec 2003
    i stopped using the churchill 25p (?) coin, it was too heavy, so hammering was a bigger bee-yotch than all the women at the lillith affair combined. it also warped, giving it the shape of a pringles chip, so now i'm using a 50p (?) coin with the queen on one side, sorry, but the other side is kinda illegable. it's sevin sided if that helps, it's not round like american currency.
  16. advance
    advance What's a Dremel?
    18 Apr 2005
    I am thinking aout doing one with two quarters put together, I will post the results if i try it.
  17. I'm_Not_A_Monster
    22 Dec 2003
    it probably wouldn't work, but good luck!
    i'm doing it with one of them brit seven sided coins about the size of a JFK dollar. i'm almost done sanding down the hammer marks, just about three little tiny spots left to go. i got an assorted pack of "tri-m-ite" wet or dry sandpaper, 220, 300, and 400, two sheets each. i reccomend it. spray a little WD-40 on the paper, and it goes so quickly, i'm probably gonna be done by tomorrow
    .:EDIT:. i really like this quick reply thing at the bottom! it's great especially because i've memorized all the smilies and tags, so i don't need to load several pages now!
  18. offroadracer789
    9 Dec 2004
    i finished the gold dollar ring today. After i got the outside done, the inside was quickly removed with a dremel and a drill bit cutter thing. I was very surprised how fast it was. It only took me about 1 hour to get rid of the inside part. I used two pieces of wood in the vice to hold the coin.
    To smooth out the outside i used a file, 220, 320, 600, 600 with water, and finally some polish. Its so shiny
  19. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    woah polish with chocalte!!! lol
  20. I'm_Not_A_Monster
    22 Dec 2003
    i saw that thing too! such a waste of chocolate, i would have hacked off my arm and used the blood to polich my can. but it would have to be a mountain dew can, because someone who doesn't drink the dew wouldn't have the guts to hack off their arm.
